Results 1 to 14 of 14
Thread: WTB . ANY B-series or H-series! ASAP?
    Southside Ridin HATCH
    Default WTB . ANY B-series or H-series! ASAP?
    i need a motor . my single cam just threw a rod and i just want to upgrade to a better motor anyways. LMK
    Cobb/Cherokee County
    i got a ls timing belt slipped so it might have a bent valve but you can get a cylinder head for the low low ill let it go for 300 come pull it
    tranny also?
    um...its a cable if you want that
    naw wouldnt be able to use it. so whats actualy wrong with the motor?
    timing belt slipped havent put the new timing belt or waterpump on so i can check if it has a bent valve or not
    well i would possibly buy it if i knew forsure that is wasnt messed up. soo lmk if u find out! thanks
    GetItFixItFlipIt Timinater's Avatar
    156 whp ls vtec. gsr tranny, harness, ecu. full swap. fast, and pulls hard. 404 418 2510, thanks tim.
    ill even install it for a little more if you would like.
    LAWRENCEVILLE
    Hella stock member!
    Default a gsr uhh
    i got a b18c ITR type r from japan has 57k on it turbo kit stage 3 clutch ecu chipped ouba data whole swap if you wont some thing fast here it is and the guy with the ls v tech should have more hp then that if not this motor would smoke it stock w/ no turbo
    hatched- my engine is faster than a gsr but slower than a type r. the type r may slightly beat it, but definatly not smoke it by any means
    bump , anymore?
    bump!. want to buy one this weekend! LMK anyone????
    stock EK
    home
    i got a b16a2 with low millage on it..im asking 1700 complet swap..
