Results 1 to 5 of 5
Thread: whats this for?(pic inside)
    Default whats this for?(pic inside)
    I am just curious what this is for,it looks like a removable bolt.Im just woundering if it is anything? guessing itl do with boost/vaccum line?
    Senior Member anothaRRR's Avatar
    Gainesville, Ga
    Yeah your right its for a boost line, you can use for your wastegate or boost controller...
    i dont know, fonzy can get gangsta, he drives a impala. hes a wife beater and a shotgun away from being Scarface
    Quote Originally Posted by anothaRRR
    so i would run the line from a vaccum source. to the manual boost controller,then from that into that port?
    this is the turbo i just ordered and i just needed to know what that was for.
    Gainesville, Ga
    U will use that port as your source to the boost controller then to the wastegate...U dont have to use it but its an option...
    TougeTougeTouge!
    Buford
    make sure that ***** is tightened down good, you might think it is, and cause you problems when you have a leak, and not know where its coming from.
