Results 1 to 13 of 13
Thread: car trouble
    Senior Member EJdm's Avatar
    Default car trouble
    coming home from the mall and my car start acting up...the battery light came on for a few seconds and off again then my power steering starts to get hard and the battery goes on and off every time i turn...i get home off engine open the hood and tells my bro to start the car on and i realize that none of my belts was running???? but my car is running??? somebody tell me what this is??? stock jdm d15b
    Jay_Bird JayL's Avatar
    McDonough, Ga
    check the tension on your pullys
    Southside
    Wow damn Santana, it sounds like the keyway in your crank came out or something, because all of the belts turn off the crank pulley and if they're not turning that's more than likely the problem. Now get that fixed bro
    San antonio 210
    you didnt finish taking the motor out ?
    naw its freaking cool and im just to damn tired (lazy)...yea i had a feeling it was that key thingy...lol
    Hope you get it fixed Santana.
    wait, call me stupid but i dont see how the car is running if the crank is not spinning. someone please explain..haha
    Southside
    Quote Originally Posted by JDM ONLY
    The same thing happened to me in my single cam. The bolt wasn't on there tight enough so it started to slide out and yea it's still on the crank and able to spin but not at 100% that's when things start to die on you and you're not able to crank up and go very far because the crank isn't fully turning the motor.
    San antonio 210
    Quote Originally Posted by EJdm
    If you have free time this week end, I could finish helping u...
    95 Ecllipse GST
    clarkesville,ga
    Wouldnt mind helping either man if i have time lol..Actually i might make time we just cant forget the beers lol..
    1999 MITSUBISHI ECLIPSE GSX
    WORLDS FASTEST MODIFIED 4 CYLINDER
    OWNER: BRENT RAU
    4G63 YUP
    1400 HP
    2200 LBS
    11,000 RPM
    86 PSI OF BOOST
    MAGNUS MOTORSPORTS
    THAT IS 350 HP PER CYLINDER
    AND YES ITS A MITSUBISHI ECLIPSE
    1/4 MILE IN 6.97 SECONDS
    BRENT RAU'S MESSAGE TO OTHER DSM'RS:
    NEVER GIVE UP
    San antonio 210
    Quote Originally Posted by dcshoeco
    check it santana, 2 helping hands....
    tell me that again but i was driving it for probably a good 5 miles before i got home and check it...and yup motor started but none of the belts was running and the crank wasnt spinning either...but my cusin told me why and how lol i dont remember but yea
    Senior Member | IA Veteran Mad Mike's Avatar
    Gainesville
    crank was spinning if the motor was running. the main pully wasnt moving because the keyway probly came out. had this problem after I swaped on my underdrive pully. forgot the keyway and started the car and it ran fine but the pully was sitting still.
    Also if the bolt was really tight the crank could spin and the pully would spin untill it lossened up and the the pully stoped.
    (yea didn't make much sence to me ether I'm to tired to try to figure out what I ment.)
