Thread: DIY: Hood Pins Install
    Shine on! Nittanys1's Avatar
    Raleigh, NC
    Default DIY: Hood Pins Install
    This DIY was done on a 1999 Honda Accord Sedan EX-L
    After a few weeks of A TON of stress I finally got my hood pins installed and buttoned up! I started working on them Jan 22nd and kept having problems lining the hood pin up with the stud that was on the frame. It turned out that I needed to get the studs that were adjustable. So after making a trip out to the closest AutoZone at 9pm I get back to the house only to have more troubles with the studs being to high and not allowing the hood to close. a few days goes by and i run to Home Depot to get a few washers to see if that would help. In the mean time I had and appointment at an audio shop to get my car looked at. so I wasn't able to complete the one side I was working on. To top if off the next day I headed out of town for the weekend and wanted to drive the accord. SO i swapped out the cf hood for the factory hood and it has been that way for over 3 weeks until tonight.
    Tonight I swapped out the stock hood for the cf one by myself...no easy task and then went to work on the hood locks telling myself I wasn't going to give up till I finished the install! There were times that I got everything lined and when i went to tighten the bolts for the final time i would move a part just a hair and the lock wouldn't line up! I almost called it quits again but knew I wanted to finish the install so I pushed on...hours later I am here typing this up to show you a little DIY of my install...
    Tools:
    - Basic tool set (wrenches, pliers, allen keys)
    - Drill & drill bit set
    - Dremel with sanding and grinding bits
    Materials:
    - Painter's tape
    - SAR's mask (or something to block the crazy fiberglass & cf dust)
    - Some rags and towels to cover work area and clean up area
    - Something to mark the hood pin and leave a mark for drilling (vaseline, hi-liter, etc)
    - Sharpee or equivalent to stencil out hood latch location
    - Silicone/RTV sealant (recommended, but not required)
    - Baby powder (for your arms, helps keep fiberglass off)
    - Install Stud
    I found a stock hole in my frame to put the stud. from there i temporarily tightened it down to make a initial mark. I took tape and placed it on top of the stud so when i closed the hood it would stick to where i needed to start drilling.
    - Installing Hood Lock
    Once I got the area for where I was to be drilling I taped off the outside of the cf hood to protect it and i slowly made my hole big enough to fit the lock into and then tested closed the hood to see if the lock was lined up.. For there i opened the hold more to fine tune the alignment of the lock.
    - Finishing
    Once I got the one hood lock working I went to the next side and did the same work to get my final results .
    Thinking back on this project, I would NEVER do it again. There was a point in time that I thought I had ruined a $650 CF hood and was so stressed out about what I had done. After stepping away from it for some time and allowing myself to think about it I had no other option other then to fix/finish my project. Had I had it to do over again I probably would have taken it to a shop and had them do it, after all if they mess up the hood they would have to replace it...had I mess up the hood I would have had to buy a new one myself if i wanted a CF hood
    Raleigh, NC
    on a side note be sure to spend $30 and get a good mask with hepa filter....its no fun dealing with the side effects of fiberglass dust!!!!!!!!
    Don Mon SiRed94's Avatar
    Morrow 30260
    just a funny story that relates... I had a buddy that was trying to figure out exactly where to drill the hole for the pins so he bolted the pins to the radiator support and slammed the hood down on them to make marks... and needless to say, the pins bent the **** out of the hood and the plates wouldn't lay flush.... but nice little write up man... you'll probably help a few ppl out... pretty clean job...
    Raleigh, NC
    thxs...your buddy was pretty umm dumb...lol
    Raleigh, NC
    can we move this to the DIY section?
    You know it.
    Certified Gearhead andrewkd16's Avatar
    Newnan/Atlanta
    hell yeah!!! good post man reps!! i need this done to my car now i can do it myself
    Gwinnett-Grayson
    thank you kindly. nittanys if you see any other ones you want moved let me or the other mods know!
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    Raleigh, NC
    ^no problem, they should all be in here now.
