Results 1 to 16 of 16
Thread: PUKEING COOLANT FROM OVER FLOW?/?
    BOOSTED GSR/HYBRID
    ON THE TRACK
    Default PUKEING COOLANT FROM OVER FLOW?/?
    MY BOOSTED LS VTEC IS PUKEING MY COOLANT OUT THE OVER FLOW ??WTF PLEASE POST IF YOU KNOW THE ANSWER TO HELP ME. THIS IS A EASY QUESTION FOR SOME SO THANKS IN ADVANCE +REPS FOR YOU IF YOU DO NOT KNOW....DONT POST
    id check the rad. cap and your thermostat
    Northwest Georgia
    is the car overheating? boosted? what?
    You have excess preasure, most likely you have a warped head, could be a stuck thermostat, but doubt it,
    Augusta Ga
    if you have a thermostat ... pull it out and see if that stops ... id put my money on thermostat ... had the same problem with my z6 .... and it was a thermostat .... kept filling the overflow bottle and then pouring coolant everywhere ....Edited for Spoolin :MY BOOSTED LS VTEC IS PUKEING MY COOLANT OUT THE OVER FLOW ??
    93 sol Si
    95 sol S
    95 sol Si
    Again, there are lots of factors.
    Is the car overheating? what size radiator? What kind of overflow (stock?) What kind of thermostat?
    how many lbs of boost? Headstuds (ARP) or headbolts (Stock)?
    Tuned or not?
    BOOSTED GSR/HYBRID
    ON THE TRACK
    tuned at mainsteam,on chrome gold,apr head studs stock HG, stock thero, stock over flow fluidyn raidator 12- 17 psi.and yes it will over heat due to loss of coolant DO I NEED TO RETOURQUE MY STUDS???????
    yes you need to retorque the headstuds.
    You should also drain the oil and look for coolant in the oil
    BOOSTED GSR/HYBRID
    ON THE TRACK
    THERES NO COOLANT IN OIL OR OIL IN COOLANT
    you prob have a sunk sleeve or slightly blown headgasket. If there is pressure in the overflow, thats not a good sign.
    superduper LLLLLLLLL
    could be bad radiator cap, blown headgasket, sunk sleeve, air pocket in radiator hose, warped head/block, head lift
    Dunwoody
    lol at the 1000 different possibility. good luck on fixing it
    BOOSTED GSR/HYBRID
    ON THE TRACK
    THANKS
    Augusta Ga
    try thermostat first vance ...... start simple then go to the hard .... good way to diagnose a problem instead of spending money for new sleeves and expensive crap when its a 5 dollar problem .,..... if it isn't the thermostat .... then do wut they said man .... but my z6 had this same problem i replaced the water pump, head,and radiator ... and it was still doing it .... replaced the thermostat .. and boom fixed .... trust me it was a headache .
    93 sol Si
    95 sol S
    95 sol Si
    Still Here LQQKITZME's Avatar
    Roswell
    + 1 thats what happened to my ls vtec.... lol But I rode on it for months
    View the world through a dogs eyes, if you can't screw it or eat it, pi$$ on it and walk away.
    Check for hydrocarbons in the coolant. Sounds like something internal might be going on.
