- Mitchell from Southside
What can I say, Mitchell is da bomb! Here's why.
Basically bought a car that I thought was in good shape until I drove it for a few days. Seemed like everything was breaking on me and wasn't running right. Vtec not working, CEL on, busted wheel bearing, timing wasn't correct, leaking oil, fuel pump about to die, wouldn't pass emissions, etc.
- Fixed oil leak with the head gasket
- Got the head resealed and resurfaced
- Compression tested head
- Installed new Walbro fuel pump (even drove me to Summit with his car)
- Hooked it up with a new timing belt for half the price
- Awesome tune up
- Fixed wheel bearing
- Installed CAT and drilled/welded hole for O2 sensor
- Vtec was dead somehow....Mitch and his boys fixed it up
Now the car is running great and the only thing left to do is probably install camber kits so my tires won't wear out. Then just need to get an alignment. Mitch and his boys are definitely people I highly recommend for any work on your car. They're cool as heck and treat you like you're right at home. Heck, Mitch even popped a beer for me and my friend.
Mitch, you and your boys have great chemistry. Keep up the great work! Will be talking to you soon.
- You may not post replies
- You may not edit your posts
Forum Rules
