Results 1 to 1 of 1
Thread: Front Omni power camber kit and rear shims...
    YEAH! bRiAnMcIvIcS's Avatar
    Default Front Omni power camber kit and rear shims...
    I went to get an alignment today and the front was 1.9 degrees off and the rear was 2.5 degrees off. So they recommended i get a camber kit for front and rear. Are the omni power camber kits decent? I can get the omni camber kit for $150 and then get the rear shim kit they offer for $15 more. Thats cool because i dont have to spend $100+ on a rear camber kit. The rear shim kit(come with 4 bolt and 12 washers) allows up to 4 degrees of rear camber adjustment, So should the rear shim kit be ok? Are the bolts longer than OEM???
