Thread: What Ecu Should i Use for My Jdm f22b throwing CEL?
    Senior Member G.C's Avatar
    Forgot
    Default What Ecu Should i Use for My Jdm f22b throwing CEL?
    I currently have a P14 (H23) Ecu in my Jdm F22b prelude. the problem is that i cant install a Knock Sensor on the engine because it dosen't require one. and its throwing a Cel on me because of the p14 which is looking for a Knock Sensor Since its For h23 which requires a Knock Sensor. What Ecu Should i get. Some1 told me bout the p39 or the p0 C . Can any1 help me here? thanks.
    :idb:
    get Mr.KID to chip it for you an he can delete the knock sensor!
    Augusta Ga
    yea chip it ... run a stock basemap ... remove knock and redline and add other goodies if you want .
    93 sol Si
    95 sol S
    95 sol Si
    Forgot
    thanks. i will pm mr.kidd then.
    :idb:
    Forgot
    someone told me that you can install a blank nut on the back of the engine and install a knock but that seems lil complicated.
    :idb:
    PM me or email me, i can get you an ecu that will eliminate the knock sensor.
