Results 1 to 11 of 11
Thread: relocate battery
    Just keepin it Dirty ulbsry02's Avatar
    Cartersville
    Default relocate battery
    so i have a ek hatch and im tryin to clean up the engine bay, where would be the best spot to relocate the battery to??
    *No_Pissed-ons!* chava_rx7's Avatar
    Braselton
    you don't need to relocate your battery wene you have V-tec!!!
    **Viva la V-tec**
    Quote:
    Boy, your better off doing drugs because there isn't any rehab or therapy for rotaries or boost.
    Senior Member boosted b's Avatar
    put it in the trunk
    Lsu tigers going # 1 again
    clayton county
    your center console. .. j/k most people really do put it in their trunk.
    I give out reps....
    In the trunk on the right hand side for a little bit better weight distribution. Although some people by the really small batteries and mount them in bumpers/etc, or somewhere else farther down in the engine bay. If you do move the battery to the trunk though, and plan to run on a track, most places require a remote cutoff switch, and the battery should be in a box strapped and bolted down.
    San antonio 210
    Quote Originally Posted by ulbsry02
    the trunk...
    NITROUS JUNKIE
    home
    use energizer double a batterys u wont have to worry about hiding any thing
    RE30
    ^^ yup... it keeps going and going and going....... lol
    put it on the right side of your truck, many people do this for weight thingy mabob purposes. when you do it make sure to use a thick 2 or 4 gauge cable and maybe a 100-130 AMP breaker right AFTER the battery for safety
    Cartersville
    i believe i'll put it in the trunk, thanks for all the suggestions
    Privateer Racing!!
    Duluth,Ga
    Mine is located behind my back bumper, on the outside of the car.Remember if you ever plan too go too the track, and battery is not in the stock location.You will need a cut off switch,it doesnt matter where you put it.
    And if the battery is inside the car, you will need battery box,vented outside!! FYI
