Results 1 to 3 of 3
Thread: What do you guys think on my build?
    DEAD DUCK 1slowep3's Avatar
    Default What do you guys think on my build?
    Ok I am going to do my build soon.Nothing too crazy just a little something.
    B16a2 block
    P30 chipped with chrom program
    STR 68mm throttle body
    Skunk2 Manifold
    440cc injectors
    PR3 head ported and pollished 3 angle valve job
    .5mm crower oversized valves
    Skunk2 stage 1 cams
    Skunk2 dual valve springs
    ITR factory exhaust manifold
    2 1/2 Apexi N1 exhaust
    11:1 compression pistons (no brand yet)stock rods
    B16a2 trans with 4.40 final drive gears
    Stage 2 clutch
    8LB flywheel
    So what do you guys think?I am open to suggestions.Thank you
    If you know better do better!
    DC5-R
    Gwinett
    skunkworks stage 1 cams are outdated. If you were to use those, you mind as well use CTR cams or '01 ITR cams which are the same. The oversized valves aren't necessary either for that build. As for those 11:1 cr pistons, before you do that you should have the block honed anyways, but in this case you should get it bored .25 over so you can use oversize pistons. These will benefit you considering the b16 platform is torqueless.
    what are your goals? HP #'s?
    P.S. Check out vteckidd's NA guide in the "ALL MOTOR" forum. Its stickied at the top. This should help you a little bit. If it was me, I would ditch the b16 block and go bigger. (LS, GSR, B20)
    your moms house
    if your building the bottom end go 1.8 or atleast high compression to make it worth your while
