Results 1 to 13 of 13
Thread: hard time starting
    1carNfrontOfu
    Post hard time starting
    On a cold start I am having to press and hold the gas pedal just a little to keep the car started or else it will shut off. After about a minute I can release the pedal and it will idle without shutting off. Can anyone tell me what is going on?
    Trogdor!!! IOnlyLookStock's Avatar
    What kind of car is it? Im thinking from your sig, a ex with a ls swap?
    Project Seksie DailyDriver : '74 Firebird 455
    The Beast : '01 Transam
    The Grocery Getter : '09 Fit. The fit is go...
    1carNfrontOfu
    yes you are correct
    Your moms house
    Are the heater hoses ran to the throttle body?
    1carNfrontOfu
    no i have a skunk2 throttle body on it
    1carNfrontOfu
    Damn!! No one on IA can help me?
    its prob a IAC/Tune issue.
    Do you have a skunk2 intake manifold? or aftermarket manifold?
    List your COMPLETE mods , injector size, ecu etc
    1carNfrontOfu
    I have the slunk 2 Intake, skunk2 68mm throttle body, stock injectors, I/H/E and and cams with stock ecu
    Your moms house
    Ever since I unhooked the heater hoses from my throttle body, My car does the same thing.
    ect could not be reading right.
    Quote Originally Posted by LSblaze
    thats your problem, you need tuning.
    When the car is warm im willing to bet it prob cranks up alot easier.
    You need fuel trimming and timing adjustments done.
    If you need tuning, PM me, i sell chipped ECUs and have a dynojet.
    you will gain alot of power with tuning, and much better idle and drivability
    Super Dave Z U L8R's Avatar
    Roswell
    i would check the coolant temp sensor as well. good suggestion
    Dave
    1carNfrontOfu
    You are right, it does start alot easier when the car is warm. As soon as I get my money up I will hit you up. Thanx for the info
