Thread: Clutch problem
    clayton county
    Default Clutch problem
    95 Integra RS. I'm not sure what the problem is but it relates to the clutch pedal. When i press the clutch, it goes str8 down. and when i try to slip it out, it feels like it's kicking my foot off of it. the clutch pedal just jumps up and the clutch grips at the end. it feels like it has a race clutch or soemthing like unsprung, but no doubt evrything's stock. any suggestions? help! and all the fluid is there. ty scotsman
    is it the clutch master cylinder or something in the tranny?
    I give out reps....
    Scottish Scotsman's Avatar
    on the road to recovery
    check the fluid
    look under the dash, see if its wet around the master cylinder, if so replace. because the seals are leaking.
    this man knows his shiate
    clayton county
    There's no leak at all. not from the inside nor from the outside. could it be something with the tranny? suggestions?
    I give out reps....
    slave cyl could be acting up, try to bleed it.
