Results 1 to 40 of 75
Thread: Question Regarding Brakes, Primarily Pads
    Default Question Regarding Brakes, Primarily Pads
    right now i'm in a crisis sort to speak in needing to change my pads on my maxima, the rear is squealing, so its time for change/upgrade.
    a friend and i were chatting and there was a discrepancy of ceramic pads. i know they have a longer life and dont create the brake dust, but is it true that they dont grab right, i mean even after a correct 'break-in' period?
    also will slotted rotors reduce the life of your brake pads? i've been thinking either getting blanks or slotted..but kinda want to go slotted incase i decide to do a lil auto-x in the future.
    bump and also move to wheels/brakes section please
    70hp FTL StraightSix's Avatar
    Central, SC
    For auto-x, you'll need to pay attention to the class you plan on running to determine if the slotted rotors are legal. It is very possible that a seemingly "innocent" upgrade will move you into a class that is less than favorable for your car. But, if you aren't concerned about being the top of the class, then all of the last paragraph is moot.
    I haven't ever heard anything regarding ceramic pads not grabbing right. All brake pads have different initial bite and friction characteristics. Any performance pad, though, will likely create a bit of dust and possibly squeal like hell. A number of the CSCC guys have used Carbotechs and liked them.
    Also, slotted rotors would cause your pads to wear more quickly. Think about it like this, if you were to rub your hand across the face of the slotted rotor, you're going to feel the grooves, right? Well, the brake pad friction surface will "feel" the same grooves. Those grooves are going to act kind of like scrapers with each pass over the swept area of the brake pad.
    Slotted rotors on a street car are, imo, overkill. You don't really need them in daily driving, or even for autocross. A high quality brake pad and fluid will be plenty for both.
    soon to be fast
    i just got ceramics on my front. they've been making a weird noise at low speeds and slow braking. its like a bumping/ sticking type of noise.
    im going back to organic.
    San antonio 210
    i dont think slotted rotors will make ur pads last longer. But it will reduce heat in the rotors...
    Central, SC
    ^^^ Heat reduction isn't why slotted rotors have slots. They do absoltely nothing for brake cooling.
    Ths slots in the rotors are there to exacuate the gasses that are created when the pads get heated up under braking. One won't see those kinds of brake temps on the street, though.
    Quote Originally Posted by StraightSix
    lol In the last 40 years we haven't had those gases.
    Slotted rotors clean the glazed surface of the pad, that's all they do...so yes they do wear your pads faster than a blank disc.
    Quote Originally Posted by osiriskidd
    You've obviously never used a race pad if you think the noise from a ceramic is bad.
    Ceramics are supposed to be quieter than organic/semi-metallic, I would suggest pulling the pads out, inspecting the caliper making sure everything is intact, then replace making sure the supplied grease was applied to the back of the pads....
    so my choice with ceramics is a 'good' choice for a DD/rarely occasional auto-x event? ill just get some brembo blanks and call it a day if this is the case, because i just purchased my ceramics yesterday
    Read this and I'll let you decide.
    Quote Originally Posted by TireRack.com
    Why Ceramic Pads?
    We want our vehicle's brake system to offer smooth, quiet braking capabilities under a wide range of temperature and road conditions. We don't want brake-generated noise and dust annoying us during our daily driving.
    To accommodate this, brake friction materials have evolved significantly over the years. They've gone from asbestos to organic to semi-metallic formulations. Each of these materials has proven to have advantages and disadvantages regarding environmental friendliness, wear, noise and stopping capability.
    Asbestos pads caused health issues and organic compounds can't always meet a wide range of braking requirements. Unfortunately the steel strands used in semi-metallic pads to provide strength and conduct heat away from rotors also generate noise and are abrasive enough to increase rotor wear.
    Since they were first used on a few original equipment applications in 1985, friction materials that contain ceramic formulations have become recognized for their desirable blend of traits. These pads use ceramic compounds and copper fibers in place of the semi-metallic pad's steel fibers. This allows the ceramic pads to handle high brake temperatures with less heat fade, provide faster recovery after the stop, and generate less dust and wear on both the pads and rotors. And from a comfort standpoint, ceramic compounds provide much quieter braking because the ceramic compound helps dampen noise by generating a frequency beyond the human hearing range.
    Another characteristic that makes ceramic materials attractive is the absence of noticeable dust. All brake pads produce dust as they wear. The ingredients in ceramic compounds produce a light colored dust that is much less noticeable and less likely to stick to the wheels. Consequently, wheels and tires maintain a cleaner appearance longer.
    Ceramic pads meet or exceed all original equipment standards for durability, stopping distance and noise. According to durability tests, ceramic compounds extend brake life compared to most other semi-metallic and organic materials and outlast other premium pad materials by a significant margin - with no sacrifice in noise control, pad life or braking performance.
    This is quite an improvement over organic and semi-metallic brake materials that typically sacrifice pad life to reduce noise, or vice versa.
    freakin sweetness thanks man..+13 or however much i'm worth to you thanks homie
    woohoo!
    hahaha...did ed talk to you?
    Photography & Design
    ... that is all
    NIKON Squad | D90
    Central, SC
    I stand corrected then.
    ... that is all
    slotted rotors FTL
    NIKON Squad | D90
    That's why crossdrilling is completely pointless!
    ALL CAPS JITB's Avatar
    my car came with drilled rotors....and a week ago this happen.. theres a story behind it, involving ice... BUT, i doubt it would have happened if they were blank....notice the red (hot as hell)color of the rotor...
    Mad Scientist xb1's Avatar
    Athens, Ga
    If I were you, I'd get a set of rotors and pads that are only for auto-x/track use. You can take your time and wait until right before the next event you want to be in, but you'll really appreciate track pads. And you can't just swap out the pads as the grooves wont line up and the rotors will have some deposits from the street pads.
    Athens, Ga
    And you don't need expensive rotors for track, at least not until you are ready to get serious. Also, I know a guy in Alpharetta who machines/preps brake swaps if you need his number.
    i've decided i'm going with brembo blanks and advance ceramics for the moment as i will not be heavily into auto-x at the moment..but i will eventually move up to hawk hps pads
    JDM TYTE AnthonyF's Avatar
    ^not a bad choice. i would have just went with OEM or adavance rotors/pads since it's not a race car.
    The Carbon Fibered R6
    Advanced, Autozone, etc. house brands are nearly all repackaged Brembo's. How many patents do you think there are for a round piece of steel with 4 or 5 holes in it?
    seriously?? didn't know that. i found a sale on ebay for all four brembo blanks for like $168 i believe shipped for my maxima . hope the sale is still there when i get the extra money
    Duralast, Beck Arnley, etc...normally all Brembo's just in a differant box.
    Alot of times Beck Arnley pads are repackaged Axxis pads.
    not trying to doubt you...but where did you get this info/get to know about this?
    I've known lots of parts suppliers and middle men for years.
    cool thanks for the info man
    soon to be fast
    checked my front brakes. there was something weird on the brake surface causing it to slip a little at low speeds. idk what it is seeing as how you'd think braking would wipe it clean.
    thats what i get for taking it to firestone instead of doing it myself.
    maybe some idiot put their greasy hands on your rotor and left grease residue on it...
    Central, SC
    For auto-x or track, I'm not a big fan of Hawk's pads. Too many of my friends are running them and getting a god awful amount of noise out them.
    I've known for ahile that cross drilling was both pointless and a really, really good way to get a cracked rotor from metal fatigue.
    ^^i knew that too..thats why i never had my mind set on drilled..always thought slotted...but now i'm sticking with blanks. ima see how these ceramics treat me then ill make/keep my decision from there on out
    I assume you mean on a daily driven car? Or since when has compromising performance & safety for comfort been on the checklist of things to do on the race track or performance driven car?
    That's like saying, "ah you know what, it's kinda hot today...i don't think i'll wear my fire resistant suit" or "my brakes are kinda noisy, I think I'll go to pads that will suddenly fade when braking for turn 10a...but at least people won't look at me when my brakes are squeaking!".
    For normal street use a race pad IS a bad idea, regardless of the noise it will never get up to temperature to properly work in everyday traffic.
    hawks are primarily auto-x pads?
    about 27-419.
    wtf?!?!?where'd u come from anthony? if u dont have anything nice to say don't say nothing at all
    There's several differant levels of Hawk pads...
    http://www.hawkperformance.com
    Street Pads
    HPS (High Performance Street) - Performance Street Compound
    Performance Ceramic - Luxury and Touring Compound
    HP Plus – Autocross & Track Compound
    Race Pads
    DTC-70 - Extremely high torque with aggressive controllable initial bite. Superior release and torque control characteristics. Brake pads designed for cars with high deceleration rates with or without down force
    DTC-60 - High torque with less initial bite than DTC 70. Superior release and torque control characteristics. Brake pads designed for cars with high deceleration rates with or without down force. Recommended for use with DTC-70 when split friction between front and rear axle is desired.
    DTC-30 - Brake pads designed Specifically for Dirt Circle Track applications. Uniquely controllable torque with smooth consistent feel and bite. Superior Release and torque control characteristics.
    DTC-05 - Developed specifically to meet the demands of lower torque Dirt Track Racing. This friction formulation provides very controllable, higher temperature
    performance as compared to stock pads.
    HT-10 - Intermediate to high torque with a smooth initial bite. Very consistent pedal feel. Excellent modulation and release characteristics.
    Blue 9012 - Medium/High torque and temperature compound with excellent brake modulation. #1 selling brake pad material for SCCA.
    Blue MT4 - Medium/High torque and temperature compound with Medium/High initial bite. Brake pads designed for circle track cars under 2800 lbs without high deceleration rates.
    Black - Medium torque and temperature compound designed to be a good, all-purpose low- cost racing brake pad.
    DR 97 - Excellent static and dynamic coefficient of friction. Smooth linear torque. Low pad and rotor wear. Brake pads specifically designed for use in drag racing applications.
    Street Pads
    Race Pads
    the HPS were what i was referring to. i heard alota pple who daily drive there cars mention those pads, so i figured they were good for a DD, and whenever there was a auto-x event i wouldnt have to worry about
    Central, SC
    There's a problem with leaping of the cliff of conclusions....there's usually a very sudden stop at the bottom involved. So, go reread what I wrote.
    At no point in this discussion have I tried to dissuade anyone from using an upgraded, ie. better then stock compound, pad for track use. Hawk's brake pads are NOT the only high performance compound available, there are plenty of others to choose from. I've heard much better feedback regarding the performance of Carbotechs than I have Hawks.
    I'd be interested in the particulars of how my statement implied that a performance brake pad compound was somehow a bad idea for the track. Even better, and keep this somewhat germane to the original question, I do not recommend a track or race compound pad for street use because the pads will never be brought to the correct operating temperature, as has been previously stated.
    saw a thread on Carbotech's on CI.com..but never went to look into it much because i've heard Hawks HPS this and Hawks HPS that..
