- need help with b18 swap
:police:
- Rep Power
- 19
need help with ls swap
ok i just did a b18a swap in a 91 crx dx i did all te wiring write but when i start the car it idles at 4500 rpms i was told it might be the intake gasket so i replaced the intake and the gasket then i was told it might be the sensors so i replaced all of them then they thoght it was the head so i replaced the head i am giving up almost does any one have any idea as to what it might be
thanks
:police:
- Rep Power
- 19
Check for vaccum leaks. Throttle cable may be over tightened as well.
x2 on vacuum leaks and tight throttle cable.
Did you switch the tps wires around?
:police:
- Rep Power
- 19
thanks for the help the throtle cable was the only thing i didnt think of its a small problem and i was thinking big
- You may not post replies
- You may not edit your posts
Forum Rules
