Thread: DSM Turbo on a Civic..
    YR88 Win! Romeo's Avatar
    Middle Ga.
    Exclamation DSM Turbo on a Civic..
    i have a spare tdo5h laying around.and i've read alot about using dsm turbo's.what all is involved? i have all the parts.like the intercooler,BOV, fmu, piping.manifold, im going to make a downpipe.but thats not big deal. any help will be appreciated. thanks.
    Augusta Ga
    home made turbo kit .. excatly wut im doing .. its a headache for first timers .... lol ..... has been for almost 2 years .. but then again im a noob at boost .... but do it man .... alot of people do that as a cheap but effective way to boost their cars .
    93 sol Si
    95 sol S
    95 sol Si
    atl
    Hope you have bigger injectors
    wide band to tune
    FUEL PUMP
    TIMING LIGHT to make sure you can retard your timing a bit
    SAFC to control the air/fuel that needs to go to the car ofter you charge it
    Fuel pressure regulator so you can control the pressure it now needs
    Thats just the first few things that comes to mind so you dont immediately blow your motor.
    Middle Ga.
    Just dont get boost happy and you will be good hahah
    Kinda lame IRL isa2o3's Avatar
    it should spool fast with that turbo, but u need dsm injectors also 450cc. walbro fouel pump or 255lph fuel pump. p28 chrome chipep ecu, 2 step ( i recomend) . and of course all the fittings and pipings such as vacuum lines and feed. good luck
    Middle Ga.
    thanks for all the advice. and i'm probably going to go with it. it should spool pretty fast. just have to put some time into it.
    Certified Gearhead miro_gt's Avatar
    Quote Originally Posted by DMH@BONES
    wide band to tune
    FUEL PUMP
    at your post, line by line:
    - yes, good to have
    - depends on the power level, may be ok with the stock one
    - do not retard your timing with a timing light. Thats retarded, lol. Do it with the ecu under boost only
    - do not use SAFC what so ever, if you like to have a somewhat reliable motor
    - adjustable FPR is not needed, stock one works fine up to 400whp or so
    too bad that those are the things that come to your mind for boosting a civic
    and you should know that there are different td05 turbos. If you happen to have a big 18G or even bigger, then it will not have a fast spool.
    good luck though, it's fun (unless your engine blows)
    Paint Guy Ricer's Avatar
    Petoskey, MI
    http://www.homemadeturbo.com/
    all you need to know
