Results 1 to 4 of 4
Thread: One cylinder not firing
    Henry Co.
    Default One cylinder not firing
    Got the motor running, timing is right, everything is right
    but cylinder #2 is not working, you can unplug the spark plug and it doesnt change the motor idle at all, while the other 3 just about kills the motor. Its sparking, has fuel.
    Also, when the motor cuts off, it wants to stay on even after ignition, and smoke comes out intake..is this a sticky intake valve?
    Newnan
    thats gotta suck
    learn to english
    Henry Co.
    Quote Originally Posted by EBP_EM1
    thats gotta suck
    thanks for your input
    Alpharetta, Ga
    take a realy long screwdriver or dowl or something start the car and check to see if the injecter is clicking... if it is it usualy means its working and your getting fuel... but first check the spark plugs for damage and gaps.
    The G Spot Hero
