Results 1 to 1 of 1
Thread: 96/00 climate control swap
    Default 96/00 climate control swap
    Tools Needed-
    1) Socket Wrench
    2) Sockets 14mm, 12mm, 10mm
    3) Open Wrench 12mm
    4) Socket Wrench Extension (at least 10in)
    5) Extended Sockets 14mm, 12mm, 10mm
    6) Philips Screwdriver
    7) Pin/Hook Screwdriver
    8) Pliers (to remove clamps)
    9) A Friend.
    10) Patience.
    Conversion Requirements
    1) 99+ Climate Control console with Climate harness (goes from console to heater core main plug)
    2) 99+ Complete heater core Box
    3) 99+ Complete Blower Box
    4) 99+ Heater core harness (should be attached to the Heater core)
    5) 99+ Center Dash vent (is contoured to position the vents to the right where the console has them)
    Step1 - Removing the Unnecassary.
    Disconnect the Battery (we dont want no surprises)
    Start off by removing the Glove box. Open it and there are two rubber holders on each side, move them in and the box comes down. then just screws the 2 bolts on each side (4 total) and tape the screws the the GB and put it aside.
    Next remove the armrest, so you can get to the shifter console so you can get to the cupholder area. i wont get into detail since this should be the least of worries. removing the cigarette console is 4 screws on each end. visible when the box box is out and the under steering wheel cover is removed.
    Once the cig console is out remove the climate console. there is a cable that goes from the climate to the heater core bottom, trace is and remove it from the pin and holder. find the two screws in the front bottom of the climate metal shell and remove those. remove the hazard and defroster buttons carefully using a pin screw driver and there is a screw behind each button. remove the radio and unplug everything from the climate control. find any screws left and by now you should be able to carefully pop off the climate bezel.
    The cluster is as simple as removing the 2 top cover screws and the 2 top and 2 sided cluster screws. unplug the cluster plugs and remove. The Steering wheel rack can be removed from the top since its attached to the dash, there are two screws that hold it by the top and 2 that hold it near the middle. and can be seen after removing the top and bottom ignition covers. leave the rack attached to the steering knuckle (you can remove for more space but remember it will need aligning afterwards)
    I thought I would show pics of what is needed to do the swap, So far you will need a 99-00 climate control,99-00 heater box with 99-00 blower motor box, an harness, due that my heater control valve is so close to the heater hose i used the heater box cable off my 97 factory one, since the 99-00 has a longer cable, so this where it would look more snugged ,an factory....this is where i am now, I will post new pics later when i get more parts, I thought this would help or change someones mind if doing it, lol,,, its not that bad, thanks for looking Joshua
