Thread: ctr piston ls vtec
    turbonetics
    Default ctr piston ls vtec
    ok here is the deal ... iam doing a compression test and was wondering how many cc should each of the cylinder be push out ???
    b16 head
    std size ctr piston
    std size bore ls block and crank
    dfafa
    turbonetics
    anybody!!!!
    dfafa
    Alpharetta, Ga
    well being that you didnt change the bore or stroke.... thenn... 1.8L which is 1800cc... or are you trying to find compression ratio because that will depend on cumbustion camber size, pistons and HG size
    The G Spot Hero
    Senior Member Nang's Avatar
    is the motor cold or hot?
    turbonetics
    hot or cold it doesnt matter ... just need to know what it should be at .... need to know if its leaking comperssion ...
    dfafa
    Alpharetta, Ga
    Quote Originally Posted by k20
    omg then do a compression test you dont need to know the CC of the cylinder.
    The G Spot Hero
