Thread: oversized pistons
    Out the game again!!
    southside of the border
    Default oversized pistons
    can anyone give me an estimate on how much more hp would i get from .25mm over pistons in a b17 block
    Soon!!
    You won't really get any justifiable hp increase. That alone will be very minimal.
    thanks^
    Soon!!
    Macon
    Quote Originally Posted by 93db2
    thanks^
    the only way you will make any more power is if your current piston rings are fried and you have no compression. Boring the cylinders .25mm over is enough to clean the surface up enough so that when you install the new .25 over pistons and rings, the compression will be back up to the normal range. There is also a very slight increase in the C/R when you run oversizeds pistons, but .25mm over will only make a very minimal change.
    Land Rover LR3 HSE
    Quote Originally Posted by allmotoronly
    Exactly! I didn't feel like typing all of that!
    Quote Originally Posted by Init2winit
