Thread: Cam install problem
    Default Cam install problem
    Problem fixed
    Thanks 1flysi reps for you
    Your moms house
    Is the bottom picture set to tdc? The cam gear timing is off in the picture that is why i ask.
    Losen the tensioner and remove the timing belt. Set the crank to tdc. On the crank pully you will see 4 marks. It will look like this, I I I I . Align the one all by itself to the timing mark on the lower timing cover.
    Then on to the cam gears. The marks I circled have to be straight across, parallel with the top of the cylinder head.
    Line them up and put the timing belt on. Rotate the crank pulley counter clock wise for 1/8 of a turn. Then tighten up the tensioner. Rotate the motor by hand one complete rotation and make sure everything is still in time.
    Make sure to check the timing ajustment bolts on the cam gears. They have been loose before on some I bought.
    Thanks for the reply
    When i wake i will follow your reply
    I do have a question on the first pic i posted i put 2 align keys in the slots which align the cams up top, if i center the marking will this throw it off? or it's different on adjustable cam gears?
    Your moms house
    The only time I use the holes you are talking about is to hold the cams still to remove the cam gears. Did you read somewhere that you use the holes to set timing? I have never heard that before.
    Your moms house
    Also did you lube the cams good before you put the cam caps on?
    I will just follow your reply
    I used assembly lube on the cams
    thanks again for your help
    Duluth, G-nett
    only way to tell if it is timed correctly is to see if the crank pully is on tdc.
    Quote Originally Posted by 1flysi
    Problem fixed
    reps for you
