Thread: weather stripping..
    Gainesville
    Question weather stripping..
    anyone know of a good place to get it? i need it for my civic lol
    Columbus, OH
    Quote Originally Posted by §treet_§peed
    Only place I found was Honda itself. And yull be sticker shocked when u see how much they rip u off for it. Mine was $78 a piece!!!!!!
    CHASE ->>>
    WHAT MATTERS
    Gainesville
    ^^^ WTF!?!?!?!?!?!?!?!?!?! its funny to think that you can find so much **** for Hondas for cheap, but then you need something so simple and uyou have to sell a kindey to buy it...lolol
    Flooding IA with JDM dc2teg2006's Avatar
    kinda off topic but, but if you need to replace your s2000 seats it will cost you 8000-9000 to replace it at honda-dealership!!
    back to topic, "Your best bet is to replace it, however, I will share with you a method I have used for years to repair weatherseals and leaky doors, trunks, and moonroofs. You will need Black RTV silicone, methyl alcohol(safer) or laquer thinner(don't drip on paint ) , Saran wrap, Chapstick. Clean the surface of the leaking gasket with alcohol twice to be sure it is clean and degreased. Apply silicone to the area that leaks. How much is dependent on the particular problem. Be very neat and even with your bead. cover the silicone with Saran wrap and close whatever it is you are sealing. On a window I would cover the window in Saran, run Chapstick along the top of the window, and roll it up. Remove the excess that sqeezes out unless it is on an unexposed surface. Leave it overnight or longer if it is very cold before you remove the Saran. By the way, Epoxy and other glues will not stick to something coated in chapstick in case you needed to first glue something down and then repeat the procedure with RTV to form the seal. This may not work for your problem at all. I don't know exactly what it looks like. Years ago I had a 79 Grand Prix that I rebuilt the door seal on this way. Those long doors didn't have a window chanel and the door seal looked like fringes. This method works EXTREMELY well on trunk seals and leaking moonroofs."
    or..
    "hondaautomotiveparts.com, or some honda tech sponsor dealerships will offer you replacement parts at a good discount"
    here are others DIY http://www.honda-tech.com/zerothread?id=2065836
    http://www.honda-tech.com/zerothread?id=1688878
    Honda-tech FTW
    ap2 lbp s2k
    Hampton
    you need the whole kit or just a piece or two?
    Gainesville
    i have a 96 civic coupe and i need both sides lol they poor like a wet whore when it rains lol
