Results 1 to 40 of 56
Thread: FS 1994 Toyota Supra Twin Turbo
    To 942JZGTE 93H22ACX's Avatar
    Default FS 1994 Toyota Supra Twin Turbo
    SERIOUS BUYER ONLY!!!! NO JOY RIDES! BUYER MUST HAVE CASH READY.... THERE IS A LOAN ON THE CAR FROM CAPITAL ONE AUTO FINANCE.
    FINANCING IS AVIALABLE THROUGH WWW.CAPITALONE.COM
    Daily driven at 585rwhp@22psi +/- 1.5psi to on a very conservative tune on 93octane and 80/20 meth injection 1250cc. Meth kit has upgraded 220psi pump. If you can get a 1.5 60ft easily capable of running 10.00 ET's.
    701rwhp 29psi. with just a/f tune from previous owner on VPC/AFC combo.
    this turbo is capable of alot more... 825rwhp output.
    1994 Twin Turbo car, White with black interior.
    Limited time.....$29,000
    The car only has 60,000 miles
    Built engine (701 RWHP by previous owner)
    Built auto tranny
    For the most part, the car was built up in Kansas City by Mark Epstein who owned the car from 1999-end of 2005 or early 2006. He sold the car to an older domestic (Trans Ams) car guy in New York state who bought it sight unseen. This owner drove the car (his first ride in a Supra) scared himself so bad he came home and put the car in storage until he sold it to me about a month later.
    Detachable 6-point cage. Rear bars go around the seats and can fit a car seat in the back or people in the back.
    Motor:
    JE forged pistons (.020" over)
    Eagle rods
    ARP rod bolts
    ARP main studs
    balanced
    torque plated
    new water pump
    new oil pump
    new timing belt
    new timing belt tensioner
    new gaskets (head, intake, turbo, etc.)
    Head:
    3 angle valve job
    titanium springs
    tiatanium retainers
    Crower 264/264 cams
    new valve guide seals, etc
    ARP head bolts
    Turbo kit:
    RPS header
    custom 60mm HKS GT wastegate
    Tial 40mm BOV
    Sound peformance SP71 GTQ with .68 exhaust housing (polished AND heat coated)
    Boostlogic Turbo Blanket
    full 4" intake
    custom 4" downpipe/midpipe (heat coated)
    Tanabe Racing Medallion exhaust
    Fuel system:
    Sound Peformance fuel system professionally installed by Sound Performance
    Custom dual feed, center return fuel rail
    883cc injectors
    twin in-tank fuel pumps
    Aeromotive fuel pressure regulator
    fuel pressure gauge
    EGR block off plate
    Snowperformance Water/meth injection 1250cc injector
    all braided stainless lines
    Electronics:
    AEM EMS 30-1100
    HKS VPC-not used but on the car
    HKS Super AFR fuel controller-not used but on the car
    HKS EVC EZ boost controller -not used but on the car
    Greddy 60mm electronic peak/hold boost gauge
    Greddy 60mm electronic peak/hold EGT gauge
    Greddy 60mm electronic peak/hold fuel presssure gauge
    tranny temp gauge
    HKS DLI ignition amp
    Blitz FATT turbo timer
    Cooling:
    Greddy 3 row front mount intercooler
    oil cooler
    tranny cooler with fan
    HKS 1.3 bar radiator cap
    Brakes/suspension:
    Stainless steel brake lines
    Synthetic brake fluid
    Metal Matrix brake pads
    new factory rotors
    Eibach pro-kit lowering springs
    Cusco front strut tower bar
    17 factory chrome wheels (with 275 40 17 Nitto DR's on back)
    Stereo:
    Sony CD head unit
    Sony 10 disc cd changer
    A/D/S 320is separates in the door (5.25" + tweeter and xover)
    (2) A/D/S RS10 10" dual voice coil subwoofers
    A/D/S 4100.2 amplifier (4 x 100 watts at 4 ohms)
    1 Farat Lightning capacitor
    Driveline:
    Boost Logic professionally built auto transmission
    Precision Industries 4200 stall
    Leatherseats.com leather interior which is black and has red inserts and Turbo embroidered onto the front seatbacks in black stitching.
    TRD Black/Red steering wheel
    Powerhouse Racing PCV system added to the car and the cam covers polished
    Powerhouse Racing upper chromed radiator pipe added
    Powerhouse Racing 4” chromed intake pipe
    Chromed Cusco strut brace
    Chromed battery hold down bracket
    Polished aluminum plate next to the radiator
    Polished power steering reservoir
    Polished engraved power steering reservoir and brake master cylinder caps added
    Modified, ported, and coated factory intake manifold
    Trac butterfly removed from throttlebody and housing area ground smooth
    Track removal mod completed
    New ash tray
    New Toyota windshield wipers
    Innovate wideband controller with gauge
    Simmons Alta wheels imported from Australia excellent condition, and the wheels look great on the car!
    18 x 9 front with 265 x 35 Pirelli P Zero tires (great condition)
    18 x 10.5 rear with 285 x 30 Michelin Pilot Sport tires (nearly new w/ about 600 miles on them)
    Almost all of the major components of this car are brand new. For example, the entire motor, the head, the turbo, the BOV, the wastegate, the FPR, the tranny, etc, all have approximately 2500 miles on them. New coil packs were installed last yaer.
    Car is driven only on rare occaisions.
    This car needs NOTHING. It does not smoke, drip or leak anything.
    The car made 701 RWHP on a dynojet dyno at 29.5 psi, tuned to 11.24:1 across the board, BEFORE the new 4" downpipe/midpipe.
    the car has a clean title. Yes, the car has a clean carfax. It has never been in a collision. The coolant is fresh, the oil is fresh, the tranny fluid is fresh. The A/C still blows cold.
    http://i35.photobucket.com/albums/d151/93H22ACX/ImportFaceOff0734edit.jpg
    http://i35.photobucket.com/albums/d151/93H22ACX/175654556cfd2ab477ce9c1df.jpg
    http://i35.photobucket.com/albums/d151/93H22ACX/1aa.jpg
    http://i35.photobucket.com/albums/d151/93H22ACX/b.jpg
    http://i35.photobucket.com/albums/d151/93H22ACX/P1010849.jpg
    http://i35.photobucket.com/albums/d151/93H22ACX/P1010848.jpg
    http://i35.photobucket.com/albums/d151/93H22ACX/P1010847.jpg
    http://i35.photobucket.com/albums/d151/93H22ACX/P1010006.jpg
    http://i35.photobucket.com/albums/d151/93H22ACX/supra1a-1.jpg
    http://i35.photobucket.com/albums/d151/93H22ACX/DSC03753.jpg
    http://i35.photobucket.com/albums/d151/93H22ACX/DSC09052.jpg
    http://i35.photobucket.com/albums/d151/93H22ACX/DSC09051.jpg
    http://i35.photobucket.com/albums/d151/93H22ACX/17598.jpg
    94 Supra= 500rwhp
