Results 1 to 18 of 18
Thread: CRX suspension
    Sorry boucha luck! Athens_Red_Rexin's Avatar
    Athens
    Default CRX suspension
    I have an 88 crx si that I want to lower correctly. I had cheap coilovers on it, and it looked awesome, but I had the camber way off and it rode like total crap! I want to lower my car really low, and it still ride pretty good and I want get camber kits and fix that too! What is a good setup to run. I want to get a Skunk 2 Pro S full coilover kit, but I don't know how good that would ride. I need some pointers and maybe some setups that have worked. Thanks for any help!!!
    1.5T AnTi-PooN's Avatar
    L'villE
    ground control coilovers with tokiko illumina shocks
    I suppose you could get the Full Skunk2 Coilovers that go for $550-600 shipped, but I have a friend that has them on his Integra and he says he doesn't like them that much. I do hear a lot of good things about Omni Full Coilovers which come in Street & Sport applications and go for $650 shipped; which I plan on getting in a couple months.
    You will never have a slammed car that will ride as well as it's designed to by the suspension manufacturer. What do you want to use it for?
    Also, keep in mind that if you want to lower your car over 2.5in, a camber kit will only help you so much until your wheels scrape in the fender well.
    Athens
    Yeah I know the tires will hit the fenders. I just want it to sit low but not ride like crap. I know it will be stiffer than stock, but I want that also so it will handle good. This is how i want mine to look...
    RE30
    simple answer mugen coilovers ftw but seriously, if u want full coilovers tein flex is a great ride. if u wanna build a suspension, kyb agx w/ ground control adjustable springs
    Koni Yellows + Ground control coil-overs. Better setup than MOST coil-over systems! IMO camber kits are overrated.
    Athens
    What about just getting the ground control coil overs?
    RE30
    they will blow out your shocks real soon...... so do it right or do that bit*h twice
    clayton county
    .. if u go low. and IT WILL STILL ride like ASSS because there is lil shock travel. get the konis and ground control with the extended top hats. you'll still be bumpy.. just less with better shocks and springs/coils
    I give out reps....
    RE30
    true that also. and konis are really good shocks as well but if you're on a budget get kyb, if not get konis. simple as that
    70hp FTL StraightSix's Avatar
    Central, SC
    Going too low will cause the car to handle poorly, too.
    YEAH! bRiAnMcIvIcS's Avatar
    Get some Skunk2 coilovers or Omni Power coilovers and Koni sport struts. Get some Omni Power or Skunk2 front and rear camber kits.
    Quote Originally Posted by KevinT707
    Omni's FTW
    I have my rear a little past halfway and i'm already tucking in the back and my fronts aren't even half way down and I can't fit a finger in
    PEENGONE Hektik's Avatar
    omni's all the way
    southside ATL
    what he said..you minuswell get the shocks too..since your car is an 88...and was previously slammed
    BABIES "R" US crew
    L'villE
    ^^^x2 that's what i said and i know first hand
    Straight up JDM!
    skunk2 adjust. springs and tokico HP blues....
