Results 1 to 17 of 17
Thread: EF guys...I need help!!!
    Senior Member mikesEK's Avatar
    over yonder
    Default EF guys...I need help!!!
    ADMIN PLEASE DELETE!!!!!!!!!!!
    I never thought I'd be asking this type of question....BUT I cant get my alternator outta my car, It's completely un-bolted but there doesn't seem to be enough room to remove it from the car
    looks like I should remove the master cylinder?!?!??!?! I figured I'd ask you guys first
    Attached Thumbnails Attached Thumbnails -mvc-001f-jpg   -mvc-002f-jpg   -mvc-003f-jpg
    PawnShopMike
    I miss-spell big words freeqwentlee thanks Dekalb Co skhool systems
    over yonder
    wow my camera takes sh!tty pics
    PawnShopMike
    You might have to go through the bottom? or try to take it out on intake side/remove intake.
    over yonder
    surely/hopefully it gotta be easier that that
    PawnShopMike
    Quote Originally Posted by mikesEK
    On my accord which is an 86, its supposed to come out of the bottow of the car. If you take the factory intake off though, then it will come out through the top, I dont have the factory one anymore so i can pull mine out either way, but go to autozone.com and use the online manual. Should help you out.
    over yonder
    good advice thanks....I was hoping some one would see this thats done it a thousand times and know the tricks,,,,,seem like on my EK it comes right on out
    PawnShopMike
    Your moms house
    Remove the two nuts holding the master cylinder to the booster. Then pull the master cylinder up and towards the intake manifold. It will come out.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    I always removed the driverside tire got it out that way.
    JDMSK8R JEY$JDM's Avatar
    NY 2 GA
    my buddy had the same problom. just jack it up and move it around until it comes out the bottom. we slide it past by the axle.
    you have to take the driverside axle out!!!!
    Your moms house
    I have owned 15 ef's and everytime I do it I pull it out the top. It takes 1 minute to remove the mc.
    then remove the gas tank, an you should be able to see it clearly, then go to the passside an remove the glove box, then take out the evaporator box a remove the expansion valve an then you can see the hole threw the fire wall... go to the other side, of the car an look under the rear seat... look for some money found any? ok thats mine, get your ass back over under the hood, look in the fuse block an remove the 7.5 amp fuse for the radio, go inside an turn you radio on, if it comes on your screwed, if it doesnt, then your almost there, go under the hood an take a BMFH (big mother fuking hammer) an hit your self in the head, nono just kidding hit the battery until you see fluid once you done that, you should see the alternator on the ground on fire, lmk if this helps!
    over yonder
    cute!!!!
    PawnShopMike
    lol thought it was also
    Your mom's bed
    +1
    lmk if i can help
    over yonder
    well fellers....I took off the lower alt bracket and she came right out of the bottom near cv axle....thanks for yalls input
    ADMIN PLEASE DELETE!!!!!!!!!!!!
    PawnShopMike
