Results 1 to 40 of 47
Thread: Boost Vs Bottle which is better?
    JDM pimpen
    Milledgeville
    Default Boost Vs Bottle which is better?
    Jus looking for a few good opinions what do yall think is better? Bottle or Boost?
    Personaly i like boost over bottle, my reason is simple, lets say your out doing you "Fast and the Furious" thing , boost stays with you all night bottle well it runs dry after a while.
    Alpharetta
    dayum u suck at life =P
    Dunwoody/Sandy Springs
    it really depends on the application.
    JDM pimpen
    Milledgeville
    ok realy what i was looking for was help to settle an argument between me and a friend so simple answers will do and please dont take the "IT ALL DEPENDS" approach. Just in general which of the two is a better choise.
    At Home
    Once again stop being an idiot.. IT JUST DEPENDS
    Lawrenceville, GA
    Boost. It can be variable for your applications, it isn't illegal to run on the street, more cost efficient and in the end has a better power band than what a nitrous bottle would. Plus wear and tear comes into effect.
    JDM pimpen
    Milledgeville
    how am i being an idiot? ok let me explain what got me to start the thread and yall can go from there. there are two guys in town that talk alot of **** to each other one with a turbo integra the other with a gsr swaped NO2 hatch and they have raced at 2 or 3 times but 90% of the time when integra boy ask hatchback kid to race his reply is "o well i dont have my bottle filled" then a few days later he calls him talken **** and tells him to meet him at tha drag stip. So the ONLY thing i wanted to know was which you thought would be a better choise over all.
    two different engines, in two different cars, with two different types of forced induction. either could be faster...too many unknown variables.
    JDM pimpen
    Milledgeville
    well that is true....lets say to identical cars same engine same wieght same hp and identical drivers the only difference is one is turbo and one has nos which of the two would you say would be faster............which would you put on your car nos or a turbo?
    on a b18, turbo for sure.
    At Home
    Quote Originally Posted by bounds25
    If you put it that way... Hatch with GSR swap and bottle.... Thats the end of it.
    But the question still has to many variables. And thats why your and idiot. An idiot who asks a question in which he dosent point out everything so that an answer will be narrowed down to a more specific answer.
    Quote Originally Posted by Staggered6
    Thats acutally wrong. Even though the b18 holds great boost, the b18 with a nitrous is a much more better. Launch, wheel spin, 60ft, Nitrous will own easily with a 75 shot... and knowing the b series to hold great power. Hence this has been proven before.
    Still too many factors to play with here. Please just do a search instead of wasting usless threads.
    i said turbo assuming cost isn't a contributing factor.
    JDM pimpen
    Milledgeville
    well thanks guys...i think. This was my first thread and now i no to be more spacific on the question *FYI* the interga was running 22 psi the hatch had a 150 shot just more info i guess i should have added .
    JDM TYTE AnthonyF's Avatar
    Quote Originally Posted by WhiteAccord
    he asked this before? can u show me a link so i can close this pos.
    The Carbon Fibered R6
    JDM pimpen
    Milledgeville
    No this was my first thread if you read above staggered6 and white accord both said "it depends" but any way
    sorry if its a repost delete the thread next time ill give my topics/questions more thought
    about this far.
    look all i have to say is this no mater what car!
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    Quote Originally Posted by callmetree19
    you got that mutha fukin right. but you know whats better than boost??
    boost WITH spray..... you know whats better than those 2?
    boost WITH spray, WITH purge!!!
    Attached Thumbnails Attached Thumbnails -purge-jpg
    Buslengths behind you
    u getting ready for F&F4?
    abcdefghijklmnopqrst afwfjustin's Avatar
    nitrous is faster than turbo given equal peak hp.
    New car:
    95 S14 with RB25DET (stock boost)
    Old car:
    Turbo S2000 400hp/285tq on 9:1 comp & 11psi
    about this far.
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    boost is better in my opinion and nitrous is not forced induction.
    At Home
    Its also about opinions too....
    How is nitrous NOT forced induction?
    New car:
    Old car:
    Quote Originally Posted by afwfjustin
    forced induction is when you increase the pressure inside the intake to that above the atmospheric pressure. nitrous does not do this it simply adds more fuel and oxygen in the cylinders. it is a separate power adder though
    But the bottle is under pressure... I think it depends on your definition of forced induction. I think NHRA counts it...
    Wikipedia currently says it is not a form, but used to say:
    "Forced induction can be used to increase the power of an engine or its efficiency, or both, without much extra weight. The ambient air that the engine is normally ingesting enters the compressor inlet of turbocharger or supercharger that is inline along the air intake tract. This effectively increases the pressure and density of the air, which allows for a much greater percentage of oxygen per volume of air intake to be added to the air/fuel mixture. The effects are an increase to the effective capacity of the engine without an increase in physical size. The forced induction approach has the advantage that the intake pressure may be regulated according to the engine speed, thus providing power from extra capacity at high speed, but without wasting fuel at lower speeds. A Nitrous Oxide system is also a form of forced induction. A simple oxidizer is injected either directly (direct port) or by a single fogger...with fuel(wet nitrous system) or without fuel(dry nitrous system)."
    New car:
    Old car:
    i believe they count it as a power adder but not FI. there is NA, FI, and nitrous
    It's cool, there's a very fine line and it's been debated a lot. I guess I was more saying that it was a "power adder".
    New car:
    Old car:
    JDM pimpen
    Milledgeville
    hey i no this is a lil off topic but kinda still goes along with it but what is the diff between propane and nos? i have heard of propan being used on deisels as well as nos jus wundering if yall could give me a good explanation?
    At Home
    WTF???/\/\ Why dont you just ****ing search... Damn....
    first nos is a brand name, the only thing i could find while i SEARCHED for this answer is that where as nitrous is a performance application propane can be used for extended periods of time and increases mpg, reduces egt's, and just overall better performance. not 100% sure though thats just what i inferred from doing a simple SEARCH. but thats fine i like to learn new things
    Don Mon SiRed94's Avatar
    Morrow 30260
    just call both of them pussies and tell them NA is best...
    JDM pimpen
    Milledgeville
    i did SEARCH....i found ane explanaiton about it lowering the exhaust temp as well as rasing mpgs also the whole feaken boring history of it and i was just hopping for a more simplified explanation......also i found that they can be used in conjunstion with one another
    Dude did you graduate high school? wundering?
    New car:
    Old car:
    JDM pimpen
    Milledgeville
    ^^I have a feeling im gonna regret this but why do you ask?^^
    ^all i can say is neither one of you can spell. AFW might be just joking but you....you cant spell. I do not know if propane works for diesals or not, but if they do of coarse they wont work for gasoline engine.
    Johns Creek
    Propane injection does work on gasoline vehicles. A lot of Viper and Supra guys use it. BTR offers a kit for the Vipers, I know.
    Using nitrous or boost are just 2 different methods of getting to the same place - more power. Neither is better or worse than the other. Each has distinct advantages and disadvantages. Do you want a low cost investment, but have a little more work to refill? Then go with the bottle. Do you not mind spending a little more initially, so that you can use it everyday? Then go with boost. Can't make up your mind? Go with both....
    ^^ are you sure your not thinking of Meth? ive never heard of anyone injecting propane..
    well...ive heard of cars running off propane so...sh*t...
    Johns Creek
    Methonol is also a usable injection, mainly to cool boosted cars down so they can add boost or timing.. I have it on my Mustang, but don't use it ever.
    Propane is different. I see it mainly used with nitrous as enrichment (cheaper than race gas). See the link. http://www.btrviper.com/nitrous.html
    Dont have to refill a turbo And turbos are street legal.
    I can't spell? I was a spelling bee champ in elementary and middle school son
    New car:
    Old car:
