Results 1 to 23 of 23
Thread: t0518g vs. gt28rs
    I am thankful for my Son
    Tyndall
    Default t0518g vs. gt28rs
    Which turbo is more capable, I would like tips from facts please. what's max whp on both of these turbos?
    83 mm GSR fully built head etc.
    02 WRX patrick4588's Avatar
    warner robins
    borg warner s366 ftw mutha ****a
    GCO Member
    NRA Member
    We did a GT28RS on a b20VTEC Del SOl. 9psi it made 285whp with a FAT powerband, it hit full boost at 2000rpms.
    Car was evil.
    warner robins
    Car was evil.
    sounds pretty badass. especially for a stock motor.
    GCO Member
    NRA Member
    140 on one wheel
    columbus, ga
    Car was evil.
    lol damn talk about tire roasting!...haha
    $queezin' triggers KidSaru's Avatar
    Athens
    GT28RS > lag
    Here is the B20 GT28 we did
    YEAH! bRiAnMcIvIcS's Avatar
    Car was evil.
    Thats badass!
    Certified Gearhead miro_gt's Avatar
    so when you can't pick the rpm signal the dyno doesn't show the TQ curve ?
    to the OP: the RS of course
    Quote Originally Posted by miro_gt
    well the TQ will show but it will be a jagged graph with unrealistic tq numbers.
    I can post the TQ, it just wont be realistic
    Heckler Dietcoke's Avatar
    Richmond Hill, GA
    How can you get realistic hp with unrealistic TQ. -_-
    2011 Camero - Fast
    1998 T/A - Slow
    Quote Originally Posted by GhostRL
    lol, reps
    WRX on Roids
    Because it is a honda it doesn't make realistic torque
    jus playn
    ok, the TQ will show 450 ft lbs, because it will be spiked.
    Some cars the tach lead is real sensitive, if it picks up a bad signal it will spike and show a high TQ number.
    You can strap a car down and do pulls with not electronics hooked up and it will calculate a HP number based on the rollers speed.
    The TQ comes from the RPM or tach lead calculated with the roller speed (HP)
    so bad tach lead, bad tq numbers.
    You guys may want to invest in some new cables or something for the dyno. I dont think that I have seen a graph come out in rpm, showing TQ or w/out the curve being all fu(ked up.
    MAINSTREAM PERFORMANCE
    Digital Box Tuning
    Quote Originally Posted by josh green
    Thats not true at all, heres proof:
    Some cars just have ignition problems or MSD sometimes makes thing hard to read. Ive been around enough dynos to know that some cars, just dont read right.
    warner robins
    my msd dizzy has a tach output to make it easy :P
    GCO Member
    NRA Member
    middle ga
    Quote Originally Posted by KidSaru
    GT28RS > lag
    lag is what the loser of the race users as an excuse. i have never had a problem with lag....and dont suspect i ever will
    Tyndall
    Quote Originally Posted by japan4racing
    Why is that? Did you finally get your block back? I called them on it. If this is Mike? Pat's buddy from Macon/W.R.
    Tyndall
    My tq.'s #'s were close to expected when Brandon dyno'd My Evo. C.O.P. FTW.
    Senior Member 95alty's Avatar
    Personally car had a GT28rs... my altima to be exact... that damn thing boosted crazy... it screamed at 4k rpms
    PIC TOO BIG
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    the td05- 18g will support more power
    but the gt28rs will spool a lot faster...
    so its on you...
    I personally would pick the 18G because its much cheaper and it still spools pretty quick (same turbine side as stock starion turbo) and supports on top end.
    GT2871R.
    Horsepower 280 - 460
    Displacement 1.8L - 3.0L
