Results 1 to 2 of 2
Thread: Stalling at 3000rpm's?????
    A.K.A Felipe Gomez Negrodamus's Avatar
    Daaaaaaknessss
    Default Stalling at 3000rpm's?????
    Ok to start i have a 2000ex and i just put in a b18b "ls" . The ls head is obd2 (1999) and the block is obd1 (1995). I am using the stock d16y8 harness and using a jumper to convert it to obd1 p75 ecu. I know that the obd1 p75 ecu does not check for a crank angle sensor and its throwing a code for the MAP, i've tried the maf from the d16 and from the ls. What and the hell could be causing me to stall out at 3000 rpms? Could it be that i need a obd1 dizzy? I dont have a clue whats causing it to stall. Any answers would help
    thanx
    Cambodia
    Are you talking about a MAP sensor? Try unplugging the MAP sensor and drive.
