Results 1 to 23 of 23
Thread: Oil pump failure experienced engine builders check in please
    Eastside Boi!!
    Dec 2003
    Eastside, ATL
    Default Oil pump failure experienced engine builders check in please
    How do u know u need a new oil pump????
    Because my oil light was flickering and i have no power
    I change out my head gasket last night cause of leak
    But its still doing it
    Your moms house
    Did you ckeck your oil?
    What engine
    What Mods
    when was the oil pump last replaced? mileage?
    need more info
    more info x2
    Eastside Boi!!
    Dec 2003
    Eastside, ATL
    Yes i have change the oil last night
    Its a stock b16a with 90k mile on it and had it since 55k miles
    And i never change out the oil pump xince i had this motor
    Im thinking i have no oil pressure
    Privateer Racing!!
    Duluth,Ga
    Quote Originally Posted by Mr.Big
    WELL U WANT THE BAD NEWS!! more then likely you are going to need new bearings and crank now. $$$$$$$$$$$$$$$$$$$
    First things first
    1) Make sure your oil pressure sending unit isnt bad.
    2) Get a mechanical gauge, and hook it up to the oil pressure sending unit an see how much oil pressure you have, you should have around 10-20psi at WARM Idel
    Or, if you want just reaplce the $100 oil pump for insurance, if the light still comes on, at least you have piece of mind
    Eastside Boi!!
    Dec 2003
    Eastside, ATL
    First things first
    Preciate that KiDD !!!
    Eastside Boi!!
    Dec 2003
    Eastside, ATL
    Quote Originally Posted by B18c1Turboed
    I hope not
    Privateer Racing!!
    Duluth,Ga
    I hope not
    Well the couple times we ahd that happen, the bearings where toast and so was the crank. Im pretty sure u better start shopping for a new crank and get some bearings!!
    When the oil light comes on,its becasue the motor went below i think 10 psi of oil pressure, that aint good for the motor!! hope it works out for u
    oil light is less than 5psi of pressure.
    as long as there is no load on the engine, it really want do any damage.
    if you do have low oil pressure an you drive the car around, it will cause the damage danny is talking about
    Eastside Boi!!
    Dec 2003
    Eastside, ATL
    Ok everthing is off now
    I have a jdm b16a
    So i just got a b16a2(99-00 si) oil pump and it seems like it dont want to fit.. Does it fit???? And i put the old one back on and went on so easy
    I heard that all b16's oil pumps fits
    im taking my break now tried of f ucking with this car
    Eastside Boi!!
    Dec 2003
    Eastside, ATL
    I just saw on the internet that the del sol b16 has more of the same parts
    that fits the generation 1 jdm b16a
    yes it will fit...I got a type r oil pump
    also if the oil sender is bad...it will not hit vtec...so that is why you dont feel power, check the sender out also....hate you do all that work an sender is bad.....
    only thing different is the new one b16a2 has a crank sensor where yours doesnt...
    Northwest Georgia
    yes it will fit...I got a type r oil pump that is the best one to get, if you havent used the one you just bought, by the type r one,
    the type r oil pump is the same part number as the B16 B18c1 oil pump. You just pay more getting it from ACURA.
    Correct....I just buy the Top dollar ****t....LOL....But the b16a2 pump will work on your b16a
    Quote Originally Posted by SPOOLIN
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    actually at my dealership, the type r pump is cheaper by a couple bucks...
    Who knows?
    hold the engine at ~6k rpms, if it starts knocking then your oil pump is bad
    Eastside Boi!!
    Dec 2003
    Eastside, ATL
    Well it still did hit vtec
    Eastside Boi!!
    Dec 2003
    Eastside, ATL
    I just order a b17 gsr oil pump Imma see if this pump fits
    Oh i have a gen 1 b16a obd0
    Northwest Georgia
    Quote Originally Posted by hondabuilder
    well how bout that ****. Ive got Wholesale so actually, I get it cheaper, LOL
