Thread: quick tranny question
    lilburn
    Default quick tranny question
    I just blew my tranny in my integra Ls and i found a gsr tranny to replace it. I didnt intend on doing this but i came accross a good deal. my only problem is i just bought a new clutch for the previous tranny and i dont wanna spend another 250 on a clutch. My question is can i use the LS clutch on the gsr tranny? if i cant then my search for a tranny continues.
    98 4 door ls (jdm tight!)
    00 civic ex coupe (sold)
    99 maxima (traded)
    94 4 door gsr (sold)
    95 4 door gsr (sold)
    94 ls (sold)
    97 accord (totaled)
    JDM TYTE AnthonyF's Avatar
    hondatech.com?
    im not a honda guy but u should be able to find it through google.
    The Carbon Fibered R6
    Scottish Scotsman's Avatar
    on the road to recovery
    also try hondaswap.com
    the guy you wish you knew crhatchzc's Avatar
    IN YOUR MOMMA'S BED!!!
    yes you can us the ls clutch for the gsr tranny it will work
    lilburn
    i know the gsr has shorter gear ratios. will this have any negative effects on my motor?
    99 maxima (traded)
    94 ls (sold)
    97 accord (totaled)
    not out of the hole. you'll be a little quicker if the gears are shorter. im sure 5th gear is the same.
    lilburn
    yeah i figured i would be a little quicker. I just didnt wanna be at 5000rpms when im goin 80 or anything like that
    99 maxima (traded)
    94 ls (sold)
    97 accord (totaled)
    im pretty sure the final drive is the same.
    Unknown
    i have a gsr trans in my ls and it is has alot better pull. 3rd,4th,and 5th are quite a bit shorter and expect to pull around 4300-4500rpms at 80mph with 195-50-r15tires. also clutch,pressure plate,and flywheel will work. also i saw 2-3 more mpg at the pump.
