Thread: Clogging up EGR will give you power?!?!?!?!?!
    Im a killer
    Default Clogging up EGR will give you power?!?!?!?!?!
    Have anybody ever tried this before? Clogging up a EGR will give you more power at high rpm because no exhaust gas is being recirculated into the combustion chamber therefore it wouldnt dilute the a/f mixture which mean more a/f will be in the C.C therefore MORE POWER!!!!!!! Try it and lmk what happen. I feel a little difference but again, it might just be all in my head.
    01civic
    Henry County
    how is that a smart way to get power?
    Heckler Dietcoke's Avatar
    Richmond Hill, GA
    Thread of the year nominee
    2011 Camero - Fast
    1998 T/A - Slow
    Trogdor!!! IOnlyLookStock's Avatar
    Quote Originally Posted by GhostRL
    Plus 1. Its got my vote!
    Project Seksie DailyDriver : '74 Firebird 455
    The Beast : '01 Transam
    The Grocery Getter : '09 Fit. The fit is go...
    I am thankful for my Son
    Tyndall
    Right next to direct exhaust injection FTL!
    It will get you about 1-2whp
    Scottish Scotsman's Avatar
    on the road to recovery
    it will eventually get you a f'd motor
    no really the only thing egr does is help with lowering emissions and keeping cylinder temps down. So removing it can pick up a lil power.
    The Nissan KING! R32Dragon's Avatar
    Sumter
    Some helpful info on the subject
    During WOT (wide open throttle), the ECM shuts down EGR. Since EGR will play no role whatsoever under WOT, it will not impede the engine's ability to generate horsepower.
    So what would someone gain by disabling EGR? Just about the only thing would be less parts under the hood. Basically, removing EGR gives you more space (although not much). To correctly disable EGR from your vehicle, you MUST at the very least, disable it in the prom. This is done by setting the minimum temperature to enable EGR to 151 degrees Celsius (maximum allowable temperature), and setting the minimum vehicle speed to enable EGR to 255 mph (maximum allowable speed). Since the engine will never reach either of these conditions, EGR will never be requested by the ECM. Since EGR will never be requested, it does not matter if you leave the EGR system all installed in its original place, or if you remove it from the car. If you decide to remove it, you will need an EGR block off plate to cover the hole in the intake manifold.
    If you simply remove the EGR system from the car, but do not disable it in the ECM, you will run into significant problems. You will likely run into detonation, the engine will run very poorly, lack power, and will probably run on the hot side as well. The ECM alters fuel and spark advance when it thinks EGR should be on. If no EGR flow is possible because you removed it, you will have a lean condition.
    Daily - '03 Infiniti G35c Sport
    Power - '03 Mitsubishi Evolution VIII
    Beater - '97 GMC Jimmy
    It keeps cylinder temps down, if you remove it, cylinder temps go up=Detonation
    You CAN remove it, just make sure you tune the car. on a stock setup i hardly doubt itll do anything for power.
    Its in your head !!!!
    Quote Originally Posted by integar94
    IA Member polishammer's Avatar
    There is only one reason for EGR and it is to help emmisions by decreasing ammount of NOx your engine produces. This is accomplished by introduction of an inert gas, gas that does not burn (exhaust), thus reducing the combustion temperatures. In theory removing EGR will rise your combustion temperature, which in turn will make the combustion more complete, which in turn will yeld more power. Again, gains will be minimal and for street purpose not worth messing with it. Unless you are full race and each hp is critical, leave it on...
    BTW, removing EGR is also
    I am the ruler of the attunement to my inner self.
