Thread: Electrical I think..? plz help
    Trogdor!!! IOnlyLookStock's Avatar
    Default Electrical I think..? plz help
    So I try and start the car tonight, and it clicks once then everything dies like the battery wasn't there. So then I clean the terminals with a wire brush and it starts just fine..
    Then when I turn it off and try to restart it, same problem.
    I tightened the connectors, and I know the terminals are clean and have no corrosion. So is there a problem somewhere else? The battery is a brand new duralast that was purchased 2 months ago...
    Project Seksie DailyDriver : '74 Firebird 455
    The Beast : '01 Transam
    The Grocery Getter : '09 Fit. The fit is go...
    JDM TYTE AnthonyF's Avatar
    could be a few things. Get new battery terminals and spray battery terminal cleaner on them. Also, make sure ur battery is still good. Since u had a loose connection the battery might not of been getting charged up.
    The Carbon Fibered R6
    1.5T AnTi-PooN's Avatar
    L'villE
    happened to me a while ago.... it was my positive lead from the battery there was a short in it. to find out if that's it turn your lights on and wiggle that cable for a bit and if they come on there is a short in it.
    autozone= $8
    REcheck your connections, next time you get it started...run the car for like 15mins, go ride around for about 10mins, let it sit for another 5minutes...then shut it off..then try it again and you SHOULD be fine...but it really sounds like a connection..if it clicks..its either a dead battery or weak ground
    Problem Solved!!
    I checked it out today in the daylight and the ground connection from the negative battery post was corroded. I got some stuff from AutoZone and its now all clean and grounded again! Thanks for your help. Reps Given out to you guys!
    clayton county
    lol!
    I give out reps....
    victory is mine .::UNKNOWN::.'s Avatar
    jonesboro, ga
    when you have a regular battery get dieletic grease it looks like a$$ but hey keeps the corrosion away they sell it at autozone in those little packets at the counter
    NO NWS
    southside ATL
    happens to me all the time...my situation was that the terminals wasnt touching....so i got a paper clip and placed it between the terminals and the battery...tightend it to make sure the touched and it worked...
    belive me...i took off my battery to see if it was dead and it wasnt..
    BABIES "R" US crew
    Quote Originally Posted by 93ludew/h22a
    last time i did my connectors i poured either ginger ale or coke, i forgot which, rinsed it off and havent had corrosion ever since
