Results 1 to 3 of 3
Thread: 240 radiator fan problem
    frikinrican
    atlanta
    Default 240 radiator fan problem
    anyways i got my car swap done about three month ago in tampa florida by XAT Racing , yeah dont go to them they suck, they installed the two radiator fan direct to the battery so every time i turned the car on the fan would come and and not shut off till the call was off, well that burned the motor inside the fan. So what i need to know is if i buy the radiator fan assembly for the sr20 motor will it come with a rely switch i can connect or will i have to wire this thing. goign out for some of this ... thanks
    Duluth, GA
    you can get a fan controller with a temp sensor, the fan will not turn on until the radiator get the the temp you set to.
    Smart Went Crazy skillzilla's Avatar
    Roswell
    x2, pep boys has them for like 20 bux. Wire it inline with the ground for the fan, it will ground the connection once the temperature reaches a certain point, and you can adjust it.
