Thread: LS CRANK EAGLE RODS IN GSR BLOCK
    M.O.B inutero93's Avatar
    valdosta ga
    Default LS CRANK EAGLE RODS IN GSR BLOCK
    WHAT IS A GOOD COMP PISTON TO USE FOR THIS SETUP ITS MY DD AND ONLY WILL BE BOOSTING MAYBE 8PSI MAX . WITH STOCK SLEEVES
    THANKS
    YEAH! bRiAnMcIvIcS's Avatar
    You would probably be fine running near stock compression with forged pistons, like 10.0 or 9.5 whatever you perfer. You can go with CP pistons, Arias pistons, or wiseco pistons. Don't forget to get it tuned.
    Privateer Racing!!
    Duluth,Ga
    LS CRANK EAGLE RODS IN GSR BLOCK is a very good combo! Run like 9:7 cp pistons and u cant go wrong with that setup!!!
    DOTCOM SpeedDreamz's Avatar
    alabama
    9.5+ is fine as long as you dont expect to go over the 8psi on pump fuel.
    Mobile Electronics and Performance
    Tuscaloosa, Alabama
    In-ground Dynojet
    valdosta ga
    thanks for the help guys i also have hondata s200 with boost on it to tune with tryn to find someone i can take it to for that ?
    any ideas?
    i lve in south ga
    MainStream Performance
    5014 Frank Aiken Rd
    Building B
    Powder Springs, GA 30127
    Phone: 678.567.9384
    valdosta ga
    THANKS
    Quote Originally Posted by bRiAnMcIvIcS
    5014 Frank Aiken Rd
    Building B
    Phone: 678.567.9384
    valdosta ga
    ALSO ITS GOING INTO A 94 DB8 INTEGRA NICE LITTLE SLEEPER
