Results 1 to 40 of 43
Thread: Girl with a tC
    MichFAIL irockface18's Avatar
    Carrollton
    Wink Girl with a tC
    Yeah, so im the obvious girl looking for good first mods for my stock tC. I def want more power, a possible turbo charger kit. I also want to lower it. Maybe even a whole exhaust system.
    If you could suggest some good brands and some good first mods for my 06 stock tc, it would be great! Thanks
    Project DX
    sell it... nuff said
    DOHC NO-TEC
    trd struts & supercharger
    ALL CAPS JITB's Avatar
    u sure u ready for a whole exhaust system?
    the tc is a nice around town little car, but just like civics.... not exactly spending your money wisley by putting forced induction on it.
    San antonio 210
    Quote Originally Posted by irockface18
    a good suspenion Tein strut assbly or cheap ok way. takico shocks with ebach springs...
    Quote Originally Posted by PsychoSquirl
    while i dont know how the 2azfe handlos alot of boost, most civics respond very well to boost.. im not sure im following your logic here
    Athens/Memphis
    My advice is to join some tC forums, and read everything you can about making power and buying aftermarket stuff. Something tells me that you might need to brush up on your info before you start spending money.
    If not, I have some sweet HID fluid for your headlights... 7000K.
    UGA: Everybody is laughing at us this year.
    Senior Member antiv6's Avatar
    g-nett
    just do springs and wheels, i know the xb's only gain 40 h/p with a supercharger, im sure the tc's arent much different, and the xb supercharger is like 4 grand
    Acworth
    With a Tc your going to run into alot of codes being thrown. Toyota has not really made the Tc as a mod friendly car. Most things you do will cause you to fail emissions. Sorry.
    CA18FTMFL BITCH!!!! JBalla1036's Avatar
    Alpharetta
    Quote Originally Posted by jdmjames
    I have 3 good friends that have went through all the bolt-ons and are now running FI. None of them have had any problems with codes or failing emissions. In fact I hardly ever hear of anyone have emissions problems on the tC
    IA's Slowest V6 AlanŪ's Avatar
    Dunwoody
    The tC handles and responds to boost very well. with the Treadstone kit on my buddies tC on low boost it ran mid 13's consistently which TryMy4.0 can attest to. with using just an afc to tune the setup he was putting down 289whp. By far the treadstone kit is the best bang for the buck if your going to go FI and not care about the warranty but the TRD S.C. Kit has seen some preety good numbers but the shafts are prone to blowing out due to poor oil flow design by toyota and vortech
    Quote Originally Posted by AlanŪ
    Dunwoody
    idk where you get your info from but I/E never threw any codes on my car unless you install the intake wrong and dont keep the MAF sensor clean you will not throw a code. The only true cat back is made by Tsudo as far as I know and it's like $230 shipped. do those first and you wont be disappointed.
    Quote Originally Posted by JBalla1036
    I havent seen any properly modified tCs throwing alot of codes. Dont over oil the filter and hook the evap and purge lines back up properly on your intake and you should be fine.
    Member
    Carrollton
    Toyota developed the scion series of cars to cater to the tuner crowd. We have no emissions here.
    Check scionlife.com
    Performance-wise:
    Look into the Tanabe concept G exhaust. Lots of scion guys are happy with that setup.
    Also a performance chip will bring some decent numbers too.
    appearance:
    Tein springs should drop it pretty well.
    Wheels are endless.
    Good luck with it.
    98 Subaru Legacy GT
    89 325i. 400hp hoon-mobile.
    decatur
    what does being a girl have to do with anything?
    Member
    Carrollton
    Maybe she thinks we'll go easy on her
    98 Subaru Legacy GT
    Dunwoody
    ^that would be like a snowball hoping not to melt in hell
    Dunwoody
    Quote Originally Posted by Logan
    Check scionlife.com
    Performance-wise:
    appearance:
    Wheels are endless.
    Good luck with it.
    I wouldnt go with that as they only make an axle back for that car like i said i would go with the tsudo
    Alpharetta
    Also check out scinergyie.com
    ASAP's Medic w/ a 1J Firefightin_tC's Avatar
    From another tC guy in the IA crowd, I strongly suggest you visit websites:
    www.scionlife.com
    This place is your one-stop-shop in terms of research. These guys know what they are talking about and will gladly get you knowledgable so that you can make a educated choice when you buy your modifications for your tC.
    If you're looking for something local:
    www.scikotics.com
    Just whoring out the name because I'm apart of 'em.
    Exhaust wise...it depends on what you're looking for. IMO, I used YouTube to get me started in my quest and there are alot of clips here that'll give you an idea of what you're getting when you drop 300+ for a exhaust.
    Personally, I'm running a Tanabe Concept G Axleback and a Megan Midpipe.
    If you're looking for something custom, find a axleback that you like, then piece it together. Axleback + Midpipe + S-Pipe + Header/Downpipe.
    Suspension, I'm rolling on Tein S-Techs and I'm on stock struts which I haven't had any problems with but I'm switching them out for Tokico Struts come this summer.
    Power-wise....screw the Supercharger and save up for the Treadstone Turbo Kit...or the Dezod Turbo Kit...can't go wrong.
    There ideas a-plenty to figure out what you want to do. Good Luck.
    IA's Sexiest Black Man 2009!
    From a Boosted Scion tC to a 1JZ-GTE SC300 to 2JZ-GTE SC300
    www.asapcarclub.com
    www.clublexus.com
    K‰^‚ð‚ā‚―‚į‚· Lucky.'s Avatar
    G'nett
    awesome, another tC owner....check out tCstreetperformance.com
    Quote Originally Posted by Lucky.
    I wouldnt check them out. Check out scikotics (sp?) They are where its at. Im basing this on the name alone though.
    white power!!!!!! .....1
    IA BK OWNER #2 BKgenŪ's Avatar
    the land of race car ya-yas.
    A good first mod is to replace your muffler bearing with a carbon fiber one... which I hear gives about a 20% power gain.
    Shop Lackies FTW Complication's Avatar
    Marietta, GA
    Quote Originally Posted by KDM guy
    /fail
    Quote Originally Posted by Complication
    /fail
    No sir its lulz
    lollerskates
    Buslengths behind you
    brandon,are u trying to make a funny?
    yes, but as it's already been pointed out... i've failed.
    $5 says the OP ebays "muffler bearing" though
    Dunwoody
    **** scionergy. they are a bunch of middle aged guys with nothing better to do then mod cars that kids are driving but then they go to meets and act like immature high school kids trust me i know first hand
    Dunwoody
    TCSP is actually a pretty good bunch of guys although the name really doesnt fit the group as only one guy is boosted in the whole crew. I am a part of them so i'm not bashing but just pointing out something
    well then ur starting the new year out as good as u ended that last
    i heard if u cut a hole in the muffler,it will free up HP?
    Quote Originally Posted by itz a jew
    The Scions are the mid age car for grandpa and grandma... dont believe me look around.
    ^ Yeah if you jam a screw driver or better yet, unbolt the muffler and then its loud.
    2JZ's bolt right in, boom instant Celica power with the reliability of G20 turbos.
    Member
    Carrollton
    You should swap in a QU33F for ultimate power.
    Rough crowd we're having here.
    98 Subaru Legacy GT
    Dunwoody/Sandy Springs
    ^lol. reps
    sir,i looked that up...and its not a engine
    What's a woman going to do with a tC? Sure not drive it I hope.
    I keed I keed.
    Good luck with your project thingy. Go RWD next time.
    Project DX
    From wat I noticed is there is a lot of daddy yankee wana bs that roll around in the tc's lol
    DOHC NO-TEC
