Thread: Kicker Components and Amps
    NWS Post King!!! ProjectWidow's Avatar
    Over there on the left
    Default Kicker Components and Amps
    ALL ARE STILL NEW IN BOX
    KX2500.1 - $ 750
    Class D Mono Amplifier
    RMS Power Rating:
    1500 watts x 1 chan. @ 4 ohms
    2500 watts x 1 chan. @ 2 ohms
    Dimensions (with end shrouds): 30-9/16"L x 10"W x 2-1/2"H
    (2) SS65.2 $ 275
    200 watts peak power handling
    8-100 watts RMS
    6-˝" Tri-Tech™ woofer cone (woven carbon-poly, Rohacell® foam, and carbon-poly backings)
    1-3/16" Tetoron® dome tweeter
    Cast aluminum basket
    Butyl rubber surround
    2-way crossover
    ZX650.4 $250
    4-Channel ZX-Series Power Amplifier
    Low Impedance Operation
    SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)
    KickBass: 0-18 dB @ 40 Hz
    Built-In Variable Crossover: 12 dB High or Low-Pass operation (50-200 Hz)
    High & Low level inputs
    Custom tooled gold plated connectors
    SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time
    Cast aluminum EndKaps
    RMS Power Ratings:
    120 watts x 4 chan. @ 4 ohms
    170 watts x 4 chan. @ 2 ohms
    325 watts x 2 chan. @ 4 ohms Bridged
    Peak Power Ratings:
    240 watts x 4 chan. @ 4 ohms
    340 watts x 4 chan. @ 2 ohms
    650 watts x 2 chan. @ 4 ohms Bridged
    Input gain control: Low Level (125mV - 5V), High Level (250mV - 10V)
    Dimensions: 22.5" L x 10-1/8" W x 2.5" H
    RS65.2 $200
    8-100 watts RMS
    1" Teteron elliptical dome tweeter
    Ferro-Fluid™ cooled tweeter voice-coil
    CIMP™ (Curvilinear Injection-Molded Polypropylene) Woofer Cones
    Enhanced BAM™ Assembly
    High-dampening strength cast aluminum basket
    Rubber Surround
    Coaxial tweeter mounting option
    Passive Crossover Network
    Spring-Loaded Nickel Plated Terminals
    Water resistant mounting hardware
    Monroe
    You got some really good stuff. GL on sale
    Project- 95 honda civic Ex
    georgia
    wow,this is awesome stuff,if i had the $$ and if i had a ride worthy of such high quality audio i would be all over this stuff. great price you could def make more splittin it up on ebay.
    yes i am....
    Dunwoody/Sandy Springs
    thats a bad ass amp
    Quote Originally Posted by MKIV VR6
    thats a bad ass amp
    It sure is!
    Bump
    All still for sale!
    your right hand man 97_luder's Avatar
    any trades?
    that is a REALLY nice setup.
    Quote Originally Posted by 97_luder
    any trades?
    Sorry not looking for any trades.
    Nobody wants a new stereo??
