Results 1 to 10 of 10
Thread: Brakes
    Certified Gearhead jdmmmm's Avatar
    Villa Rica
    Default Brakes
    What is the best way to take the rotors of my integra without taking it to the shop?
    JDM TYTE AnthonyF's Avatar
    take ur rims off, undo the 2 bolts for the caliper, 2 bolts for the caliper bracket, then if ur rotors have never been taken off before, there will be 2 screws holding the rotor on. you have to undo those.
    The Carbon Fibered R6
    Villa Rica
    what is the best way to undo the screws?
    there is a special impact screw driver that is supposed to be used for it. Your car might not even have them anymore. You can try a screw driver, if that doesnt work, put some balls behind it. if THAT doesnt work then you'll prob need that tool. Advance and Napa has rent-a-tools.
    clayton county
    ^^ yups. i lost my little screw driver impact thing. lol it's only 20 bucks. try not to use a philips alone..
    I give out reps....
    Villa Rica
    Thanks for the help
    ~helpin u get out of red +8~
    If you dont have an impact driver you can try using a chizzel and a hammer to brake loose the phillips head screws. Once they are loose they can come out easily with a screwdriver.
    Columbus, OH
    I'll also help to pull u from the grave
    CHASE ->>>
    WHAT MATTERS
    clayton county
    i guess i'll chip in my one block lol
    I give out reps....
