Results 1 to 11 of 11
Thread: tracy, dan, mike, batlground and any 240 peeps
    R.I.P Leisa USMC_is300's Avatar
    north alabama
    Default tracy, dan, mike, batlground and any 240 peeps
    okay this is a fresh motor if i listed everythign done to it it would be way to long so here are the basics
    sr20det redtop
    wiesco pistons
    eagle rods
    hks 264 272 cams
    toda solid lifters
    blah blah blah
    okay here is the issue car cranked after priming ran fine once the ecu un screwed its self. but there is no oil gettting to the cams. the oil squirters on top of the cams stay dry. i have pulled them off blew air through them and there clear, also without them installed no oil through the galleys in the cam caps. so my question is what in the world could cause this everything cam out of the hot tank less than a week ago all new parts everything new.
    new oil pump
    also there is supposedly an o ring on the front cover (oil pump that goes to the outlet from the pump, if this gets rv around it what would be the results. would they be the same if the o ring wasnt there
    any and all assistance will be greatly apreciated i am stumped
    Smart Went Crazy skillzilla's Avatar
    Roswell
    Its really common for SR oil pans to get dented in during motor shipping, so check that first. It is the lower oil pan, the clearance is really tight (less than a quarter inch). Take the pan off and look for an oval mark where the pickup was hitting, and bend it back out if you see one. Should be quick, you can do it with the motor and sway bar still installed.
    Roswell
    Oh BTW, sounds like a nice build, post up some pics (if nothing blows up )!!
    In the Fucking A
    Do you have oil pressure at all, Its pretty odd for you to just not get oil to the head. Sounds like you have a dead pump or the pick up isn't getting oil.
    Matt
    I fucked İhris's mom
    north alabama
    its a brand new greddy oil pan so the dent is not an issue, it could be the pick up is to low i will check that first thing. i get 40 psi of oil pressure just nothing to the top of the head the cam area
    Roswell
    Hmmm, just going to throw something out there but are you sure the HG is not the issue? My memory is a little fuzzy but I remember reading something from one dude that installed a B13 SR20DE headgasket and blocked some oil passages to the head. Im probably mistaken but hey, worth a look I guess
    north alabama
    thats a good question, its a cometic head gasket so i will have to check that anyone know for sure if there is a diffrence in the head gaskets
    Roswell
    I looked at some pics online and they seemed identical, I think I was mistaken.
    north alabama
    actually view this image and you can see the diffrences,
    from the cometic sight
    there are 2 extremly diffrent head gaskets but here is the discription from the site
    it says sr20de/det 91-96 16v 2.0l (rwd) 2 int. oil holes or sr20de/det 91-96 16v 2.0l (fwd) no additional oil holes
    north alabama
    issue resolved oil pickup was too close to the bottom of the pan no clearance, thank god for play dough
    Roswell
    Awesome, man, glad you got it figured out
