Results 1 to 10 of 10
Thread: motor mount madness
    Atlanta, Ga
    Default motor mount madness
    alright i have a b16 in a del sol and my buddy JDMjoe86 has a d something in a 92 eg.
    our driver side top engine mount looks the same. why is this?
    he is convinced they should NOT be the same because it is a D vs. B, but them bit*hes are the same. and if you look at the picture of the coffee and cream eg, it has a different mount with the b series in it. and when i go to buy mounts at autozone or whatever the mount that is seen on the coffee and cream eg is what it brings up for MY del sol driver top mount but its not it
    discuss:
    top is the dirty b, bottom is the oldie d
    clayton county
    off subject but clean car!!!! lol
    I give out reps....
    Atlanta, Ga
    wish it was mine haha
    i think its jdmjeff's
    LAWRENCEVILLE
    you have a b16 style mount on yours which will bolt to the stock d series style mount. if you look at the one on top of the transmission is also the same. there are two diffrent style mounts the mount under the cam gears the b16 style and the style found on 94+ integra ls and gsr. which is whats picture on that hatch.
    Hella stock member!
    LAWRENCEVILLE
    edit some of the 92-95 "EX" model civic with the d16z6 also used the integra style mount.
    Hella stock member!
    Smyrna
    The difference is not the mount, it is the bracket that bolts up to the motor.
    98 EJ8 - Stolen ( Thieves)
    LAWRENCEVILLE
    Quote Originally Posted by silversol
    thats what i said
    Hella stock member!
    Atlanta, Ga
    cool cool...i was just kind of concerned that someone may have fabbed up something to fit a d series mount that wouldnt be as effective.
    the mount that is on the coffee and cream hatch is like $130 and the mount on my car is $37.99 haha, so i guess its good that i have the cheap one but it may be a piece of shi-t
    to my knowledge, all b/d series driver side mounts are the same . . . well not exactly the same, but you can use either one LoL
    Smyrna
    There is a difference depending on which bracket you use.
    I bought a driver's engine bracket for a 99/00 SI and the studs are like ( o_O ) whereas the Teg's are like ( O_O ). I know that is probably about as a clear as mud without a real picture.
