Results 1 to 4 of 4
Thread: 02 civic brakes/suspension issues
    ALL CAPS JITB's Avatar
    Default 02 civic brakes/suspension issues
    alright , i have a issue with a noise form the front end, like a popping noise every now and than. While turning or even hitting a bump. its not consistent, but it happens more the sharper the turn is, or the begining of a sharp turn. My axle boots are fine, but im thinking its my tie rod ends? Visually they look ok, but they are flat. would that cause the noise? i hope it is, its a easy fix..
    and my brakes squeak like crazy after 10-15 miles of driving.. but the pads are 2 months old if not less, and have plenty of life left. They arent any special pads, so i didnt expect them to be the quietest. But they are squeaking loud at the end of stops. i was gonna take them apart and re grease them with brake quiet.. will that work? or do i just need to get better quality pads?
    Mr. Azzhole BUGMAN's Avatar
    Trailer Park
    Boots may be fine but it sounds like your CV's are going out. I am pretty sure that you can get them for under $100 each brand new and they are not too bad to change out.
    Brakes sound like you have gotten them really hot a time or two.
    Zoom Zoom kfzemx3's Avatar
    atlanta
    sounds like CV
    for your brakes have you done any hard stopping? or are these cheapy pads? get you a decent set of pads if they are you dont have to go as far as getting a set of hawks or ebc, a set of raybestos pads would work fine, good brakes and they give you a pretty decent warranty on them
    I spend money on HP not Brand Names.
    08 Infiniti G37s 6MT [The Daily Beast]
    05 Mitsubishi Lancer Evo VIII MR [Sold]
    01 Lexus Is300 [Under Construction]
    93 mazda Mx-3 SE 2.5 Klze [Sold]
    92 mazda mx-3 GS 2.0 Kfze [I Killed it]
    i was indenial about the cv being worn..lol... the car is being drove to california, this weekend, i dont know if ill have time to fix it...
    But the brakes werent the cheapest, i believe they were wearever.. but i knew i should have just gotten the same ones i would have gotten for my gt. but i havent been doin any hard braking its jsut a daily ole civic.
    thanx for the advice.
