Thread: AT 240sx trans problem
    iTrack matthewAPM's Avatar
    Otto-Flimm-Straße, Nürburg
    Exclamation AT 240sx trans problem
    My friend is having trans problems on his 1990 240sx. It is an automatic.
    He says that the trans can be shifted from park to reverse to drive without pressing the brake or pressing the button on the shifter. and now that the transmission can be shifted freely, the key wont come out the ignition.
    Any ideas? he needs it done for the mountain run tomorrow
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    btw, it does engage in every gear
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    Blooregard Q. Kazoo turbosx©'s Avatar
    femalesaplenty
    wiring
    I got dinner to goto.
    DUH-KYOO-LUHHH
    Quote Originally Posted by matthewAPM
    found the problem! lolol
    jk. but there should be some kind of mechanical switch that or sensor thing that tells the ignition that the car is in gear. since the shifter button and the brake pedal have no effect on changing gear, im guessing that whatever sensor or switch thing is there is stuck.
    DUH-KYOO-LUHHH
    BUMP FOR D RAWK
    5 speed swap I have a tranny
    Ummm mine does it.....doesnt it do it while tha car is on or off? Mine will let me change gear freely, until i almost hit r form a drive gear. It will not go into reverse form a drive gear thank god, but is his doing it?
