Results 1 to 28 of 28
Thread: Lsvtec not making power as expected
    GetItFixItFlipIt Timinater's Avatar
    Default Lsvtec not making power as expected
    I just finished my lsvtec and got it tuned and it is not putting out as much power as i expected.
    I used a 1997 b18c1 head with about 100000 miles
    I used a 1991 b18a1 block with about 200000 miles
    crower 402a cams
    pr3 pistons
    stock ls rods with arp rod bolts
    dc headers
    no cat, but has a temporary bendy pipe
    two and a quarter inch pipe crush bent all the way back
    the car dynoed at 156 hp and 135 tq
    I was expecting the hp to be much closer to 200 hp.
    Any help or advice?
    everywhere & nowhere
    did replace all bottom end gaskets?
    new rings w/ psitons? who set them? are they set correctly (clearances)
    what do u have timing set at?
    Smackyaselfville
    change the cams, and a better exhaust system made or bought, preferbably 2.5 inch instead, where do you rev too? hope at least 8, Itr cams would be better, is it a stock intake manifold?
    Project Vox has begun
    Turbobricks.com member
    GeckoSquad
    Quote Originally Posted by boosted_nonv
    Wrong answer. He needs to make sure the basic build is dialed in before he throws more money at it. There are B16s that lay down this power w/ minimal mods... he needs to hold off on that for now.
    Quote Originally Posted by Timinater
    crower 402a cams
    pr3 pistons
    dc headers
    Any help or advice?
    youre nowhere NEAR 200whp with that build. youll be lucky if you make 170whp.
    156whp is about right for that setup, its nothing special just an OEM internals lsvtec. dont expect big numbers. your making great TQ and about stock GSR whp numbers. which is about right.
    Some things that stand out are:
    2.25 in exhaust, thats killing you, do a MANDREL BENT 2.5in exhaust. Either get a Thermal or Skunk2 "R" exhaust.
    DC Header- Garbage, the worst of the best headers. if this is the USDM version, you might as well run a stock header. Pick up one of my Hytech/Rages for 7-10whp gain
    What intake manifold? if its stock, then youll need an AEBS or Skunk2/Blox
    But yeah hate to burst your bubble but thats not a 200whp build, not even close.
    ^^ You think he should dyno at 156whp Mike?? That seems low to me. * shrugs *
    with a 2.25 in exhaust, stock intake manifold, USDM DC Header, sure absolutely.
    those cams arent that great either, never been impressed with crower VTEC cams
    Right on, I think I am keying in on the HP too much - and not theTQ #. Makes sense. Well - you REMEMBER my "new 3 piece crower cams" thread - since then Crower can kiss my ass. (Crower, not BC). You don't get 2 chances to f.uck up my motors... LOL
    NEW CROWER 3 PIECE CAMS!!!! GANGSTA!!
    known as Charles
    Here is the graph. You can see that it wants to make power because it ramps up nicely after vtec but then flattens off at the topend. You normally don't see long flat spots in a Honda all motor graph unless the motor is having problems breathing. With the higher compression you need to be able to flow more air in and out. Like Mike said the DC header with a 2in collector is killing it along with the exhaust. I would do a compression test also to make sure everything sealed up good on the build. Finally 200whp all motor in GA is hard to do esp with stock parts. Later.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    Quote Originally Posted by Main Stream
    exactly
    I still think a compression check is in order. And as usual, I appreciate the education from you guys anytime I can get it. + a million
    TQ numbers are pretty good but yeah HP seems about right to me. I only made 168.51 WHP/123 TQ when I dynoed last month.
    Attached Thumbnails Attached Thumbnails -crx-dyno-chart-11-15-07-jpg
    your moms house
    they all said it.
    your running out of air up top you can look at the graph those cams are somewhat comparable to skunk stg 2's and should be making power up to atleast 8500rpm before it starts to fall off. start with header and exhaust then go with a intake manifold bigger throttle body and tune from there it should pick up some power after that.
    it should make mid 170's with a good tune
    ALEX #1Beaver's Avatar
    damn good info on this thread
    Proud Mr2 Turbo Owner
    Subherbs
    BORE IT OUT! make it a 2.0 or 2.1
    and i take it you got it tuned at mainstream? since they are showing your run... what a waste of money
    1996 4dr Integra
    1992 Mr2 Turbo
    RPM = Ruins People's Motors
    Quote Originally Posted by Mr2raceworks
    ^^ meaning? waste of money? how so??
    Certified Gearhead dougatl12's Avatar
    police precinct
    yeah how is it a waste of money he started good just small issues that where over looked slowed him down learn about motors before u open your mouth
    Subherbs
    learn about mainstream before you take it there, i know my honda motors thank you
    1996 4dr Integra
    1992 Mr2 Turbo
    highest hp n/a d-series in ga
    highest hp n/a b-series in ga
    highest hp n/a k-series in ga
    yea...learn mr2racewack!!
    PWNT
    Who is MR2Racewerks?
    does anyone know him, and why does he care about hondas when he drives a toyota?
    HONDA RIDIN LOW BOY
    i go some skunk 2 stage 2 cams $400
    Smackyaselfville
    now you agree with Mike pimp, I was basically saying the same thing, same point i was trying to make, just worded it wrong, trust me homie i know waht you gotta do to make 200whp
    GeckoSquad
    not to sure what to say... u guys know your stuff iam learning my-self! lol
    Around metro-ATLANTA & IA!!
    u should spray, but get tuned with it.
    that would be a temporary fix. I would go with at least a jdm 4-1 dc and a 2.5" mandrel bent exhaust. those cams you have are not that bad and I def. would not swap them out for ITR cams. and even after you do this and an IM/ TB you still should not expect more than 180whp
    come get some superman's Avatar
    Dream Land
    gl
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    LOL, I make that (hp wise) with my b16
    want more power
    -get better cams
    -upgrade your valvetrain to rev higher
    -increase your air flow (better manifold, larger bore tb, larger diameter intake)
    -open up your exhaust (replica hytec header with a 2.5in exhaust should do the job)
    that should help
