Results 1 to 13 of 13
Thread: idle up and down?
    BOOSTED GSR/HYBRID
    ON THE TRACK
    Default idle up and down?
    my b18 idles up and down anyone know why?
    Kennesaw, GA
    IACV
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Kennesaw, GA
    Cold weather, probably fast idle thermo valve
    OF*C
    1.5T AnTi-PooN's Avatar
    L'villE
    TPS
    west of ATL
    mine too.
    when i had my d series i turboed it and i had the idle problem with larger injectors but when i adjusted the fuel with the vafc it smoothed out?????
    now i have a b18 ls swap 94 in my si hatch and it idles too low then sometimes not always idles up and down! i was told that the throttle position sensor goes bad on them and will cause this but have not spent the 80 bux on trying this. i was also told that any tps would work but havent found any proof of this either so someone must know!
    i have heard of alot of people having this issue but noone knows how they fixed it or wont tell!
    "You can't spell CrAP without APC"
    4 sale:
    69 mercedeshttp://www.importatlanta.com/forums/...d.php?t=122901
    west of ATL
    see is it iacv or tps?
    4 sale:
    Certified Gearhead JDMef88's Avatar
    Gainsville, GA
    same thing happened to my on my y8, if you turn your car off, take off neg bat term, and adjust the screw on your throttle body to the left it cuts your idle all the way down and it made my cel go away and my up and down idle...thats my 2 cents...
    Wtb 96-00 civic aftermarket struts asap
    San Diego, CA
    Check your CEL, and check your vacuum hoses...
    JDMadness ==> EvasiveEF9
    BOOSTED GSR/HYBRID
    ON THE TRACK
    theres no cel and if i had a vac leak i would have a boost leak also it doesnt do it bad just a little when the heat is on
    is this on the new motor?
    Challenge Everything 2ndGen.Teg's Avatar
    LaGrange,GA
    EGR valve mabye?
    Oct 2003
    Most of the time when a Honda idles like that, it's more than likely the O2 sensor has failed. The first to do is to take a needle and backprobe it into the wire. Take a multimeter (I have a snap on vantage pro for graphing purposes) and while still plugged in, watch the voltage. A good working O2 sensor still plugged in is gonna try to produce any where from .300 to .700 due to the computer doing the rich/lean switch (basicly for emissions) and you have to be certain that it's switching in that manner to make sure it's not stuck reading too rich or too lean. Another thing you can try is the bench test. Unscrew it and with heat put a bottle of butane on it and be sure to move it around the tip in a circular manner or your destroy it as it will surely burn a hole through the insulator. The O2 sensor should produce when fully hot 1.27 volts and when you take the heat away from it it should drop like a rock. Anything under that and it's no good. Try that and see if it works.
    Your moms house
    Does it do it when the motor is hot or cold?
