I'll **** you up!!!
It will take you around 10 to 15 minutes to get everything installed (know the instructions are kind long but it doesn't take anytime to set up)... PM me if you have any trouble.
Follow these instructions to play online...
Ok, To Be Simple "Mame32 Plus! Plus! 0.117" Has Finally Released "CPS3" Emulation. "Street Fighter III 3'rd Strike" Is A Well Known "CPS3" Game.
I've Decided To Put Together A "Mame32 Plus! Plus! 0.117" Kit With Kaillera Support For Online Play. Yes, That Means We Can Play "Street Fighter III 3'rd Strike" Online With Other People Around The World.
Ok Here Are Some Instructions:
Download Mame32 Plus! Plus! 0.117 Here:
Download This File: Kaillera-0.9-sdk
Extract It To The Same Directory As Mame32 Plus! Plus! 0.117. Not A Folder, The EXACT Directory.
Once Finished Downloading Extract The Files To Wherever You Want.
Ok, Now For The "Street Fighter III Third Strike" Game, You Will Need To Download ALL Of The Following Three Files:
Download Street Fighter III 3rd Strike USA Version:
File Size: 63.30MB
sfiii3.zip
Download Street Fighter III 3rd Strike Japan Version:
File Size: 130KB
sfiii3n.zip
Download Street Fighter III 3rd Strike CHD File:
File Size: 64.66MB
sfiii3_chd_file.zip
Put ALL Downloads In The Folder Titled "roms" In The "Mame32 Plus! Plus! 0.117" Directory. Extract ONLY the "sfiii3_chd_file.zip" Do NOT Extract "sfiii3.zip" or "sfiii3n.zip". Once Extracted Make A "New Folder" In The "roms" Directory, And Name It "sfiii3". Put The File "33s000.chd" In The Folder Just Created In The Roms Directory (sfiii3).
Open Up The Application "Mame32++ 0.117.exe". Click "Options" On The Control Bar Menu, Then "Directories". Make Sure It Says "Roms" Under The Menu. Once Confirmed Close The Directory Box.
You're Going To See Two Version Of The Game "Street Fighter III 3rd Strike". It Should Look Like This:
Street Fighter III 3rd Strike: Fight for the Future (USA, 990152)
Street Fighter III 3rd Strike: Fight for the Future (Japan, 990152, NO CD)
You Can Play Either One, The Difference Is The "USA" Version Is In English, And Takes A VERY Long Time To Load. The "Japan" Version Is In Japanese, And Loads Like Any Other Game. You Can Configure They Keys To Anything You Like By Pressing "TAB" While The Game Is In Play. Press The "Enter" Button To Select What Is Highlighted In The "TAB" Menu.
Online Play
Ok To Play Online Simply Do The Following:
- Go To "File"
- Select "Kaillera Netplay"
A Window Will Pop Up. Type Your "Username" In The Box On The Bottom. On The Dropdown Box On The Bottom With "Connection type:"
In Front Of It, Select "Excellent (30 keyframes/s)"
You Must Repeat The Above Process Over Again To Play Online In The Future.
You Can Connect To One Of The Servers By Clicking On Them, Or Connect To The Server Which I Reccomend Connecting To, Which Is "Daroms Server". You Can Access This Server By Clicking On The Box Labeled "Enter IP". A Small Box Will Popup. Enter "dfw.daroms.com" Then Click "Connect". Once Your In A New Box Will Popup. Either "Create new game" Or "Join" A Game. You Can Only Use This Rom To Create Or Join A Game:
When Creating, Or Joining Games, Remeber Only That It Must Be TheEXACT Name Above.. Don't Worry Though, It Is Pretty Much The ONLY Version Used.
If There Are Any Concerns, Questions, Or Further Help NOT ALREADY EXPLAINED IN THIS POST, Ask Away
