Results 1 to 18 of 18
Thread: RWD Corrado engine still in the front!
    Soul Crusher RUFFIAN's Avatar
    in your nightmares
    Exclamation RWD Corrado engine still in the front!
    This is continuing a theme from the other night. this is the best setup I've seen as far as handling.
    Attached Thumbnails Attached Thumbnails -rwd-corrado-jpg   -rwd-corrado-2-jpg   -rwd-corrado-3-jpg   -rwd-corrado-5-jpg
    N/A>>><<<BOOST
    I would like to see a LS1 Corrado! That would be badASS!
    Senior Member WalkS's Avatar
    Middle Ga
    aw snap that the stuff right there. I would rock that.
    JJSPEC Racing
    BAD ASS
    You must spread some Reputation around before giving it to ruffian again.
    i need ae86 parts canadianrcis's Avatar
    marietta
    thats bonified bad ass
    hachi roku groove
    Ooltewah
    would rather drive this one then the one you posted the other day
    Daytona Beach
    very nice. what engine?
    BK ALL DAY
    gangsta
    GECKO SQUAD MEMBER
    MSS RACING REPRESENTA.....
    the saga continues....
    Quote Originally Posted by ruffian
    How much does it weigh, they've always been extremely overweight....
    Wonder if that an Audi GT Coupe rear end/suspension
    in your nightmares
    turbo VR6
    N/A>>><<<BOOST
    in your nightmares
    im not sure on the curb weight, but this is a 500+ hp car. the fact that he rotated the motor and pulled it back towards the fire-wall and made it RWD, It should be a handler.... provided the spent some coin on the suspension. I like this better than the rear engine setup because of the dreaded "snap-steer" effect.
    N/A>>><<<BOOST
    Be Vivid magneto198's Avatar
    ATL/lenox/Lville
    looking good, keep up the good work
    IAs Most Hated OG!! BLK JDM's Avatar
    Anyone have any real info on this car as in what tranny and rear end was used? Anymore engine shots? I'm trying to figure out how the intake manifold and piping for the intake is ran?
    Quality Perfomance and Fabrication!!
    BodyGuy Civic_H2b's Avatar
    nice
    - Phu
    in your nightmares
    Quote Originally Posted by BLK JDM
    1992 Corrado SLC
    Owner: Richard Hawse
    Occupation: Owner, European Auto Care
    Engine: 2.8 litre VR6 12v with 2.9 EIP low-comp pistons, Cunningham chromoly rods, balanced and machined short block with ARP hardware, ATP ported cast manifold, Precision PT67 turbo, Turbonetics wastegate with stainless dump tube, 4" Garrett FMIC core, 2.5" aluminum plumbing, DTA Pro 8 engine management with 3bar GM map sensor and integrated Innovate wideband sensor, GReddy blowoff valve, ECM 5/8" fuel rail with 660cc Siemens injectors, ECM aluminum short runner intake with velocity stacks to equalize runner length, EIP big bore throttle body, ECM stainless 3" downpipe and side-exit exhaust, ECM aluminum 12 gallon fuel cell, Aeromotive A 1000 fuel pump, FPR and filters, Russell braided line, Northern aluminum radiator, aluminum fan shroud with Flex-a-Lite fans
    Driveline: 02A bellhousing with ECM billet adapter plate, BorgWarner T5 five-speed with forged gear set, 0.59:1 fifth gear, EIP/Clutchnet six-puck copper disc, EIP flywheel, A1 Driveshaft 3" chromoly driveshaft, Mitsubishi independent rear suspension control arms, diff and axles with drilled 5x100 hubs
    Suspension: Bilstein front coilovers with 400 lb H&R springs, Bilstein rear inserts in custom Mitsubishi shock tubes with 300 lb H&R springs, Neuspeed front sway bar and upper stress bar, six-point chromoly rollcage
    Brakes: 12.3" cross-drilled Brembo front rotors with stainless lines, Hawk pads, Wilwood proportioning valve, front wheel line-lock solenoid controlled by e-brake
    Wheels & tires: 17x8" front, 17x9" rear three-piece BBR wheels with 225/40 front, 245/40-17 rear Bridgestone Potenza S02 tires
    Exterior: Passat sunroof, Euro chin spoiler and headlights, Rieger grille spoiler and rear wing, smoked tail lamps and front runners, Hella fogs, painted original Aqua blue pearl
    Interior: black leather trim, Schroth Rally harnesses, Momo steering wheel and shift knob, Auto Meter Ultra-Lite tacho, speed, boost, oil pressure, coolant and voltage gauges, Innovate XD-1 digital AFR gauge, A'PEXi boost controller
    Audio/visual: Pioneer CD head unit, Boston Acoustics 6.5" front components and 4x6" rear speakers
    Thanks: Richard Hawse Sr, Al Bush, David Dorr, friends at EIP, Bill Schimmel and anybody who said it wasn't possible, European Auto Care (410/599-2345)
    N/A>>><<<BOOST
    very nice
    Thats too functional to be Euro..... lol Just kidding. Sweet car!
