Results 1 to 11 of 11
Thread: WHY?
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    San antonio 210
    1st time ive seen that shi-t...
    gwinnett
    Nice price.
    Why not
    Turbo-Wired
    East Cobb
    Quote Originally Posted by jadakid88
    I'd assume the same reason that people put them into 240's. Except a Supra is a body that actually could have a V8 and not be utterly ridiculous. I must also add, that engine should have been mounted about two inches further back if possible, I wonder how nose-heavy that thing feels to drive...
    Mr. Azzhole BUGMAN's Avatar
    Trailer Park
    Why not
    Agreed. Some of the coolest things I have seen has come from a few rednecks sitting around bored with spare parts. Sometimes it doesn't turn out so well but sometimes it does.
    This is kinda cool but it would blow my mind if I pulled up beside it at a red light and heard the engine rumbling.
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    because smallblock 350 swaps cost less than d series swaps and the 7m motor sucks monkey nuts
    What's your question on it? This is the general tech forum.
    Quote Originally Posted by Kaiser
    That engine is under 700 lbs with a 4 speed transmission and the 7M-GE is around 450 plus the weight of the transmission. Not too much difference and it will put out quite a bit more power and torque
    Turbo-Wired
    East Cobb
    The 7M-GE is mounted a little bit further back, more of the weight is toward the center of the car. I agree with your point to some degree, and for going in straight lines it's fine for the power/weight difference. Like I said though, I wondered how nose-heavy it felt. If you really think the frame and body balance is enough to offset the new engine, then hey, maybe I'm wrong. I was wondering, I do want to drive it. I just think V8's are overrated.
    Oh, and Speed: There is no question, he's made a couple of these that should probably be moved to "car talk."
    Edit: I should reiterate again too, that I think a V8 in a supra is not a dumb idea. I do think a V8 into a 240 IS a dumb idea, and I'm just commenting on how it would drive. Supras are not terribly great-handling cars to begin with, adding even an extra 100lbs on the front and adjusting that weight forward just a little would require some serious suspension retuning.
    Trogdor!!! IOnlyLookStock's Avatar
    Perfectly stated. I couldn't have put it any better myself.
    I like the 350 swapped into the back of a crx myself..
    Project Seksie DailyDriver : '74 Firebird 455
    The Beast : '01 Transam
    The Grocery Getter : '09 Fit. The fit is go...
    If you use a later model pushrod V8 you can get an aluminum block with it....they are lighter than the cast iron KA's with tons more power and torque with even more potential.
