Results 1 to 3 of 3
Thread: crankshaft position sensor
    GetItFixItFlipIt Timinater's Avatar
    Default crankshaft position sensor
    will lsvtec run without a crankshaft positon sensor?
    the one in the dizzy.it can run but not well. if your talking crank fluctuation on the actual crank yes it will run fine
    Your moms house
    Are you using a obd2 Ls? If you are and you put the motor in a non obd2 car then it will work.
