Thread: WTB: B-series Honda Stuff!!!!
    Macon
    Default WTB: B-series Honda Stuff!!!!
    I need some stuff to finish up my swap:
    B-series water outlet, bolts to the t-stat housing and has a port for the cooling fan switch
    B-series water neck, bolts to the head (b16A)
    Upper GS-R timing covers,
    Also, the lower one for 96+ that covers the ckf sensor on the oil pump. (i have the other style)
    B18B crank pulley
    99-00 Si Power steering pump, maybe brackets too
    Im not looking to spend a fortune here, i can get this stuff from the dealer reasonably cheap (minus the p/s pump&pulley), but id like to clean out someones garage and get a lil help on my build!!
    98 Ex - B16
    92 accord - H23
    95 teg - shell
    88 std - shell
    98 Lude - broken :/
    06 Sierra 4x4
    Southside
    I might have some of that Steve
    Macon
    bump....still need everything except for the t-stat/waterneck stuff!!!
    98 Ex - B16
    92 accord - H23
    95 teg - shell
    88 std - shell
    98 Lude - broken :/
    06 Sierra 4x4
    02 WRX patrick4588's Avatar
    warner robins
    i have the upper timing cover, but i cut the portion that loops over the cams. you can have it, just come pick it up.
    GCO Member
    NRA Member
    L'ville
    i got a b18b crank pulley
    pm sent
