Results 1 to 24 of 24
Thread: egay halo headlights + HIDS question
    Default egay halo headlights + HIDS question
    Iv been curious if my egay halo projectors are taking away the full HID effect..i have McCulloch 30k HID kit(yes there really 30k!)they look whiteish/blue..but Nitro and the person i bought them from says 30k are pink? would putting these in normal headlights bring the true color and brightness out?
    sorry if its a noob question.im just curious.
    Senior Member BlkCD5's Avatar
    it will cause a lot of glare.
    Quote Originally Posted by BlkCD5
    the projectors or OEM headlights?
    Ap2
    oem works better
    Project RB.
    Senior Member steedracer's Avatar
    winder
    got any pixs
    Quote Originally Posted by steedracer
    got any pixs
    i have pics of the halo headlights.with hids on
    the McCulloch ballast
    dont hve pics of the oem headlights..but i have 1 sitting in my closet if u want to see it? lol
    At Home
    For the egay headlights the brightness will be affected because of quality... OEM headlights will have a bad glare.... best is do a retofit...
    got any pixs
    front view( before i took off the body kit!) i personally like the halos at night and the black housing.
    lights up the street pretty good when its just me,but around other lights and oncoming traffic it kinda deadns them. if that makes since.
    Be Vivid magneto198's Avatar
    ATL/lenox/Lville
    yes thats true. ebay headlights use sheap plastic that can shift the light or block the output completely.
    The higher in temperature you go, the less light output. Halogen lights put out the same amount of lumens as a 12k HID would. 30K HID= NO lumens.
    Quote Originally Posted by magneto198
    Plastic is plasting wether is cheap or not. When it's new AND if it's clear, it will put out the same amount of light.
    so my 30ks arnt anything special or any good?
    Quote Originally Posted by 1NonlyAccord
    Nothing other than looks. If you want REAL lighting then you need to stick with 4300k which is what comes stock in most cars. That puts out 4500 lumens if I'm correct as opposed to 1500 lumens that halogen/12000k HID put out. I'm not quite sure on the exact amount of light going out but it is almost three times more.
    Quote Originally Posted by aaronfelipe
    looks as in the color? as im told its supose to be pink/lavender.(sp)
    The higher your go up in temperature, the less light is put out.
    Bottom line, if all you care about is looks, then you have to sacrifice visibility. Personally, it makes more sense to invest that much money on something that will IMPROVE your overall driving experience (4300k-6000k).
    paint booth
    i have had 6000k and now i have 8000k and i really cant tell that much difference but i have heard anything over 8000k is a a waist.
    **H.I.D KING** Nitro's Avatar
    STMN GA
    JDM TYTE AnthonyF's Avatar
    you do know, just b/c it is a higher K rating, doesnt mean its the brightest light. and why would u want 30k? i have 10K
    The Carbon Fibered R6
    i just traded sum guy on here for my MTX thunder 4051? amp for them..so they were kind of free because the amp and jl w6 was givin to me also.
    Certified Gearhead Mchnhead2k5's Avatar
    N.Druid Hills
    just go out and buy some HID bulbs that are in the 4300k to 6000k range that should fix your problem.
    1999 Corolla CE & 1988 Pontiac Fiero
    Northwest Georgia
    looks like you need to aim your headlights.
    gwinnett
    http://hidsources.com/product_4117_405.html
    What you guys thing about that website, the fog beams for my FC ?
    Gainesville
    8000k is where it's at and yeah it owuld help to aim them up a tad bit. you can also take out the peice of metal inside the projector that tends to block some of the light
    N.Druid Hills
    whatever you do, don't take out the metal piece/cutoff for the light. You'll be blinding on coming passengers.
