ok i just fixed my 1995 240sx, i changed the valves on it. and now its running rich, it works good but i can smell the exhuast stinks and throws black smoke. what could be the problem and how could i fix it.
Stock KA24DE ? What kind of Valves did you use ? OEM Stock ? Aftermarket ?
Plain and Simple, it's unburnt fuel. Running way too rich, check if you got any oil leaks around. Might help if you lift the car up somewhere around a local shop. Check if Oil is entering an Area that is not allowed. Like for example, Spark Plug chambers. Plus when you replaced your valves, did you use a new valve cover, and head gasket, it can be a stressed valve cover gasket, or maybe a stressed head gasket.
240atlanta.com
zilvia.net
240sx.org
ask around those websites. l8r man.
Originally Posted by 13b_soldier
i got a new head gasket and old valve cover.
Could be a faulty coolant temp sensor or a dirty connection. Cause your car to stay in open loop...
I'm sorry, I meant to say Valve Cover Gasket.
