Results 1 to 5 of 5
Thread: Poor Man R owners...
    Cambodia
    Default Poor Man R owners...
    Out of curiosity, what timing belt and water pump combos are y'all runnin?
    I've got a GSR timing belt with a Type R water pump and there's significantly a lot of belt slap goin on. I'm thinkin I should swap to a Type R belt or a B16 belt... I need some suggestions.
    "big $hit poppin"
    in the slums where killas get hung
    i used a r h2o pump & gsr belt...while it lasted!
    BOOSTED GSR/HYBRID
    ON THE TRACK
    i got the belt slap. so got a ls belt with my gsr water pump and is stoped
    LS water pump and LS timing belt
    GSR/B16/ITR water pumps are all the same
    GSR/ITR belts are the same
    B16 belt is shorter because of the deck height
    DO NOT RUN LS WATER PUMP AND GSR/ITR BELT. The LS pump has a different number of teeth.
    If you have "belt slap" adjust the tensioner, if that doesnt help, you may have stretched the belt, replace it. Replace the tensioner as well.
    Cambodia
    Yeah, I took into consideration the deck height. I'm thinking the belt stretched. The tensioner is as high as it gets. I guess it's either Greddy or Toda...
